## Acceed NRU-160-FT: A Rugged Edge AI Solution for Demanding Industrial Environments
Acceed has launched a rugged edge artificial intelligence (AI) computer called the NRU-160-FT, designed for harsh industrial and outdoor applications exposed to dust, heat, and vibration. This system is ideal for applications requiring fast data processing at the point of operation, such as robotics, automation, transportation, and construction machinery.
### High-Performance AI Processing
- Equipped with NVIDIA Jetson Orin modules (Orin NX and Orin Nano).
- Offers up to 100 INT8 TOPS of AI computing power.
- Can process 18 Full HD video streams simultaneously.
- Provides energy efficiency with approximately 25 W power consumption.
- Real-time neural network model execution is possible with CUDA and Tensor cores.
### Fanless Cooling Design
- Utilizes a conduction cooling architecture that dissipates heat directly from the chassis without the need for ventilation.
- Eliminates the need for fans and filters, reducing maintenance requirements.
- Offers stable operation in enclosed and sealed environments.
- Operates without performance degradation in temperatures ranging from -25°C to +70°C.
### Industrial Connectivity and Sensor Integration
- Supports camera and sensor integration for mobile and industrial applications.
- Up to six GMSL2 cameras can be connected for automotive and vision systems.
- Multiple Gigabit Ethernet ports and PoE support are available.
- M12 connectors provide robust industrial connections.
- Existing drivers support common image sensors, enabling rapid application deployment.
### Power Management and Mobility
- Supports a wide input voltage range of 8-35 V, allowing use in vehicle-based applications.
- Automatic power-on/off control is provided via vehicle ignition.
- CAN-FD, RS-232, mini-PCIe, and M.2 expansions enable communication modules and 5G connectivity integration.
### Compact Design and Flexible Installation
- Compact structure with dimensions of 199 × 136 × 49 mm, saving space.
- Designed for heat dissipation from external surfaces within sealed enclosures.
- Suitable for construction, agricultural machinery, autonomous vehicles, logistics systems, and infrastructure monitoring applications.
### Operational Efficiency and Cost Advantages
- Fanless design and low power consumption reduce energy costs.
- Long lifespan and low maintenance requirements reduce operating costs, especially in fleet and off-grid systems.
The Acceed NRU-160-FT is an edge AI platform that can operate reliably in harsh conditions and enhance performance in industrial automation and mobile applications with its real-time data processing capabilities.
