Seamless Drive Replacement in Legacy Fieldbus Systems with Hilscher
    ### A New Way to Modernize Legacy Fieldbus Systems
    Replacing drives in older PLC-based Fieldbus systems has long remained a significant challenge in the industry. Replacing faulty or less reliable drives often requires updates to PLC code, specialized tools, and lengthy downtimes. These resources are often limited or inaccessible.
    ### A Practical Solution from Siemens and ElectroMatic with Hilscher Technology
    The solution developed in collaboration between Siemens and ElectroMatic eliminates this problem by using pre-configured communication modules built on Hilscher's multi-protocol netX technology. Siemens SINAMICS drives can be easily integrated into existing DeviceNet networks without changing the PLC program.
    Hilscher's technology, with its ability to bridge different industrial protocols on a single platform, provides seamless communication between Siemens drive systems and Rockwell control networks. This enables systems to work together smoothly and without interruption.
    ### An Effective Approach for Brownfield Modernization
    Thus, instead of replacing entire legacy systems, operators can incrementally upgrade their existing systems, leveraging the advantages and cost-effectiveness of both ecosystems. Thanks to this solution:
    • Downtimes are reduced
    • Maintenance processes are simplified
    • Component selection becomes more flexible
    Openness, flexibility, and interoperability in communication reach the highest level in the industry.
