Metso's Robotic Split Strip Solution for Copper Electrowinning
    Metso is revolutionizing cathode stripping operations in copper electrowinning with its new solution, the Outotec® Robotic Split Strip. This technology, which combines a robotic system with advanced hydraulic control, increases precision while also improving operational flexibility and sustainability.
    ### Robotic and Hydraulic Technology
    The Robotic Split Strip separates cathode sheets using a robotic gripping system instead of mechanical components. This compact and integrated design provides higher accuracy and flexibility in the stripping process. It is suitable for both new plants and retrofits in existing electrowinning tankhouses.
    ### Performance Advantages
    • Compact design reduces space and structural requirements
    • Fewer mechanical parts lead to lower maintenance needs
    • High reliability in movements thanks to advanced hydraulic control
    • Increased flexibility with modular robotic placement
    • Operational efficiency improves with less downtime
    • Delivers effective results even with challenging and sticky cathode sheets
    ### Operational and Environmental Impacts
    The integrated design simplifies installation and maintenance, supporting rapid commissioning. This results in a more cost-effective lifecycle compared to traditional technologies. Furthermore, reduced weight and footprint contribute to minimizing the environmental impact at facilities.
    ### Advanced Technology in Hydrometallurgical Processes
    With over 40 years of cathode stripping experience and more than 350 installations, Metso is a leader in the field of hydrometallurgy. The solution is based on extensive experience in leaching, solvent extraction, electrowinning, and precipitation technologies.
    ### Conclusion
    Metso's Robotic Split Strip system integrates robotic and hydraulic systems, taking automation and optimization in copper electrowinning a step further. This technology supports modernization in mining and metal refining processes by increasing efficiency, sustainability, and ease of maintenance.
