Teknoloji Muhabiri
Engineers gain faster, easier drive setup with Nidec’s Connect V3, offering step-by-step guidance, live tuning, and centralized support tools.
Commissioning servo drives is often a bottleneck in automation projects. With Connect V3, Nidec delivers a major update to its PC-based tool, offering guided setup, auto-discovery, and real-time diagnostics in one streamlined interface. Engineers can test axes, tune motion, and troubleshoot with built-in scopes and logic visualization. Combined with centralized resources at DriveSetup.com and integration with Machine Control Studio, Connect V3 makes commissioning and maintaining servo systems faster, simpler, and more reliable.
Connect V3 shows drive setup, tuning, and diagnostics in a single interface.
Connect V3 shows drive setup, tuning, and diagnostics in a single interface. Image used courtesy of Nidec
Connect V3 is Nidec’s updated PC software for setting up and maintaining servo drives like the Digitax HD series. The interface has been overhauled to make the software more intuitive, with step-by-step guides that help users through tasks such as motor selection, communication setup, and basic motion tests. The built-in diagnostic tools reduce the need to jump between different programs, helping teams catch issues earlier and keep systems running reliably.
Redesigned Interface and Setup Guidance
Connect V3 features a redesigned interface with guided steps for drive commissioning. Users can auto-discover drives over Ethernet, Serial, or Bluetooth without manual IP setup. EtherCAT systems are also supported, and TwinCAT users can bypass EoE configuration entirely.
Motor selection is handled through a dropdown list, and axis movement can be tested directly in the tool. Connect V3 also has built-in help prompts that can help reduce the need for reference manuals during setup, which gives integrators a straightforward format and minimizes unnecessary clicks, making it practical
for both experienced users and those less familiar with the system.
Real-Time Tuning and Motion Analysis
Connect V3 features an integrated scope that allows users to monitor their system's behavior in real time during tuning. All key parameters, such as gains, motion profiles, and I/O status, are readily available on one screen, which helps reduce time spent jumping between menus. Visual tuning with live plots and adjustable sliders makes it easier to see step response and refine control settings with minimal trial and error.
Connect V3 can provide real-time system tuning with a built-in scope and unified parameter view.
Connect V3 can provide real-time system tuning with a built-in scope and unified parameter view. Image used courtesy of Nidec
The logic diagram viewer provides a dynamic view of drive logic, including signal flow and I/O states, aiding in commissioning and troubleshooting. Drive parameter sets can also be backed up and restored quickly for use across multiple axes or machines.
Machine Control Studio Integration
While Connect focuses on setup and tuning, more complex control logic can be programmed using Nidec’s Machine Control Studio. This IEC 61131-3 compliant environment supports Structured Text, Ladder Diagram, and other standard automation languages. It also enables programming for onboard PLCs and integrated MCi modules and allows for Ethernet network data configuration.
Machine Control Studio enables IEC 61131-3-compliant programming for Nidec drives.
Machine Control Studio enables IEC 61131-3-compliant programming for Nidec drives. Image used courtesy of Nidec
*Machine Control Studio enables IEC 61131-3-compliant programming for Nidec drives. Image used c
Innovation from Nidec: Advanced Coding and Centralized Support Platform
Nidec has accelerated coding with features like IntelliSense autocompletion and simplified working with multi-block and repetitive functions. Compatibility with internal and open-source libraries allows developers to work on reliable code instead of starting from scratch. Additionally, live monitoring windows and online variable tracking facilitate immediate intervention.
Along with the new Connect V3, Nidec has launched a centralized portal service called DriveSetup.com. This platform brings together software, documentation, and installation tools under one roof, making them easier to use. Users can perform drive setup, tuning, and diagnostic operations with integrated and guided tools. Comprehensive documentation and software updates are also available on the platform. This ensures faster and more error-free delivery and maintenance processes.
