Robotic Code Generation Software from RoboDK
    ## Robotic Code Generation Software from RoboDK
    RoboDK, a robot simulation software company, has launched RoboDK CAM, a software that accelerates robotic machining processes. This platform shortens commissioning times by generating robot code directly from CAD designs and simulations.
    RoboDK CAM supports automated robot applications such as milling, drilling, deburring, cutting, and additive manufacturing. Users can simulate entire machining processes, detect collisions, and transition from 3-axis to 5-axis within a single environment. It also eliminates the need for manual and vendor-specific robot programming.
    ### RoboDK CAM Features
    • Integrates with CAD/CAM systems like Fusion 360, SolidWorks, and Mastercam, extending existing workflows to industrial robots
    • Provides an end-to-end solution for the entire robotic machining process
    • Supports milling, drilling, deburring, cutting, and additive manufacturing in automated robot applications
    • Offers collision detection and seamless transition from 3-axis to 5-axis
    • Eliminates the need for manual robot programming
    • Reduces testing times by up to 40%
    • Reduces commissioning times from days to minutes
    RoboDK states that RoboDK CAM enables manufacturers to implement automation projects faster, reduce production downtime, and achieve quicker iteration of machining processes. For system integrators, it is noted to shorten project durations and decrease the engineering effort required to commission robotic machining cells.
    This software significantly reduces testing time, depending on complexity, allowing automation projects to be completed more quickly and efficiently.
    Other robotic technology developments presented by Automation World continue to shed light on the industry.
