High-Precision Eddy Current Displacement Measurement System for Industrial Applications
    ## High-Precision Eddy Current Displacement Measurement System for Industrial Applications
    MICRO-EPSILON has introduced the eddyNCDT 3005, a compact eddy current sensor system designed for high-precision displacement measurements and robust integration in industrial automation environments.
    The eddyNCDT 3005 is an eddy current sensor system that provides fast and precise displacement measurements, specifically developed for industrial measurement tasks and automation solutions. Its compact design, high temperature stability, and durable construction make it suitable for use in challenging industrial conditions where reliability and measurement accuracy are critical.
    ### High-Precision Measurement with Temperature Stability
    • Sensors based on eddy current technology measure with micrometer-level accuracy.
    • Thanks to active temperature compensation, measurement results remain stable even with significant temperature fluctuations.
    • The system's operating temperature range is above -40 °C to +200 °C, making it suitable for thermally demanding industrial environments.
    ### Compact Design for Series Applications
    • The robust construction makes the eddyNCDT 3005 ideal for integration into machines and industrial systems with conditions such as pressure, dirt, oil, or high temperatures.
    • The controller, sensor, and integrated cable are factory-matched, ensuring high measurement accuracy.
    • With a diameter of only 12 mm, the controller allows for installation in confined spaces or hard-to-reach areas.
    • Depending on the application, the system can be configured for ferromagnetic or non-ferromagnetic materials.
    ### Flexible Integration into Industrial Networks
    • The measurement system is designed to operate at ambient temperatures up to +125 °C, with an optional range of -20 °C to 180 °C.
    • It is resistant to pressures up to 10 bar.
    • Modern interfaces allow for easy integration into existing automation networks and adaptation to customer-specific needs.
    The eddyNCDT 3005 combines high precision, robustness, and integration capability, offering an ideal solution for applications requiring fast and reliable displacement measurements in challenging industrial conditions.
