Siemens SIRIUS 3RC7 Smart Connecting Module
    Transforming Field Data into Real-Time Control: SIRIUS 3RC7 Smart Connectivity Module​
    How much could you reduce your operational risk if you could see what was happening in the field not just when a fault occurred, but before a fault occurred?
    In industrial facilities, instantaneous monitoring of motor outputs, load characteristics, and thermal behavior is no longer a luxury, but a core component of a proactive maintenance strategy.
    🔎 What Does SIRIUS 3RC7 Provide?​
    The SIRIUS 3RC7 Smart Connectivity Module creates data transparency between motor starter systems and the PLC infrastructure, bringing critical field-level parameters into the digital environment.
    📊 Measured and Monitored Parameters​
    • Phase-based voltage and current
    • Active power and load status
    • Thermal behavior and temperature monitoring
    • Operating hours and switching cycles
    • Overload and abnormal condition information
    Thanks to this data:
    • Load imbalances are detected early
    • Thermal stresses can be analyzed
    • Energy consumption can be optimized
    • Insights into motor health can be generated
    🛡 Integrated Protection + Proactive Monitoring​
    The 3RC7 doesn't just collect data;
    it actively protects equipment with integrated overload protection functions.
    • Early warning mechanisms
    • Pre-fault trend analysis
    • Reduction of unplanned downtime
    • Increased MTBF
    This structure supports the transition from the classic "reactive maintenance" model to a condition-based maintenance (Condition Monitoring) approach.
    🔗 SIMATIC & TIA Portal Integration​
    • Full compatibility with SIMATIC PLC systems
    • Fast commissioning via TIA Portal
    • Direct access to parameterization and diagnostic screens
    • Standardized engineering approach
    This shortens field commissioning times and reduces engineering costs.
    ⚙ Installation Advantage​
    • Minimum cabling requirement
    • Compact design
    • Easy integration into existing SIRIUS motor starter infrastructure
    • Panel space optimization
    🎯 Conclusion​
    With SIRIUS 3RC7:
    • Field-level data transparency
    • Energy and load characteristic analysis
    • Early fault detection
    • Safer and more sustainable operation
    What truly makes a difference in the Industry 4.0 vision is not just digitalization;
    it's being able to use the right data, at the right level, and at the right time.
