## Seamless Pump Performance with SEEPEX Smart Joint Access
SEEPEX has introduced its new Smart Joint Access (SJA) pump design, offering continuous operation and reliability in demanding industrial environments. Integrated into their BN progressive cavity pump, this innovation provides direct visual access to both joints through a wide opening in the suction housing, all within a compact design.
### Designed for Efficiency and Durability
SJA enables the precise handling of shear-sensitive, abrasive, or corrosive media, allowing for quick and effective condition assessment. It is particularly ideal for applications with limited space, mobile production units, underground operations, and both stationary and skid-mounted installations.
### Reliability in Rock Blasting and Chemical Applications
In rock blasting, the precise and consistent dosing of explosive emulsions is critical. The SJA in SEEPEX BN pumps contributes to the reliability of emulsion transfer and dosing through quick access to the joints. This offers a significant advantage in loading blast holes and other sensitive chemical processes.
Magalie Levray, SEEPEX Business Development Manager for Mining, stated, "With Smart Joint Access, operators gain direct access to the joints through a large inspection opening, reducing downtime and ensuring reliable, consistent pumping of viscous, shear-sensitive, and abrasive emulsions."
### Smart Joint Access Features
- Direct visual access to joints through a wide inspection opening in the suction housing
- High-pressure capability with a compact and uniformly walled stator design
- Compact hydraulic drive option for truck-mounted mobile units
- Electric motor option for underground and stationary installations
- Lower displacement hydraulic option for reduced oil consumption and lower total cost of ownership
- Stainless steel or steel casing options
- Wide chemical compatibility with NBR, EPDM, or FKM stator materials
### Application Areas
The SJA-supported BN pump is used in many industrial processes where sensitive chemical and abrasive media need to be reliably transported, such as rock blasting, shotcrete, mine dewatering, tunnel excavation, infrastructure projects, and dam construction. It enables quick assessment of pump operation through regular visual inspections and pressure tests.
SEEPEX offers an ideal solution for high operational efficiency and continuous production with its smart pump technology.
