## Cabinet Mounting Made Easy in Industrial Motor Control with the SNAP-IN System
Schneider Electric has introduced the TeSys Deca SNAP IN motor control solution, which reduces cable clutter and shortens assembly time in industrial automation systems. This innovative system aims to increase both productivity and reliability for panel builders and OEMs.
### Installation and Operation
SNAP-IN connection technology allows cables to be inserted directly without the need for special tools. This system, which replaces screw terminals, significantly reduces manual wiring steps, saving up to 92% in assembly time. Additionally, the use of pressure-type connections instead of screws increases consistency in assembly and improves process repeatability.
### TeSys Deca SNAP IN Features
- Fast and tool-free wiring with SNAP-IN connection technology
- Push-in system replacing screw connections
- Potential to shorten assembly time by up to 92%
- Easy integration into existing motor control architectures
- Robust mechanical design for industrial environments
- Plug-and-play support for new installations and retrofit projects
### Operational Advantages
For panel builders and machine manufacturers, shorter wiring times mean shorter assembly and commissioning times. This reduces time-to-market for products and maximizes system availability in critical applications. Fast installation and maintenance minimize downtime.
### Technical Positioning
TeSys Deca SNAP IN is part of Schneider Electric's product range focused on simplifying motor control engineering. The tool-free connection technology, compatibility with existing systems, and design for industrial operating conditions offer an ideal solution for applications where operational efficiency, reliability, and fast assembly are priorities.
