## CertiFiber Max for Data Center Fiber Certification from Fluke Networks
Fluke Networks has introduced CertiFiber Max, the third-generation optical loss test set developed on the Versiv platform for high-density data center fiber certification. The device offers native test support for up to 24 fibers in a single test cycle, accelerating the multi-fiber certification process.
CertiFiber Max directly supports MPO and MMC connections, enabling simultaneous measurements of fiber loss, length, and polarity without the need for fan-out cables and adapter chains. The device provides full integration with LinkWare and ProjX workflows, reducing setup time while maintaining Tier 1 certification accuracy.
### CertiFiber Max Technical Specifications
- Measures up to 24 fibers in a single test cycle
- Direct MPO and MMC connection support (12, 16, 24 fiber MPO; 16 and 24 fiber MMC)
- UniPort field-changeable adapters
- Simultaneous measurement of fiber loss, length, and polarity
- Integration with LinkWare and ProjX
- Complete test in less than one second
- No need for fan-out cables or adapter chains
- Adapter replacement possible as connection type changes in the field
- Standard jumper reference method for optical loss measurement
- Guided workflow tracking test reference setup and test count
- Multi-fiber visual fault locator (VFL)
- Integrated duplex power meter (for SC and LC connections)
- Optional end-face inspection tools
- Compatible with ProjX work management system, data upload via LinkWare Live
CertiFiber Max is specifically optimized for today's data center installations. As part of the Versiv platform, it works seamlessly with existing field reporting and project management systems to provide high-precision Tier 1 fiber certification and simplifies the testing process for modern multi-fiber connectivity structures.
