The Conveyor | January 2026 Industrial Automation and Robotics Developments
    ## Innovations in Industrial Automation and Robotics: January 2026
    The new year has begun with numerous product and technology developments in areas such as power distribution, safety, industrial computing, and vision systems.
    ### Sanyo Denki: Standby UPS with 200% Overload Capacity
    An efficient standby UPS system with 200% overload capacity for high inrush motor loads has been introduced.
    ### Aaeon: Modular Workstation Compatible with MXM 3.1 Type A/B GPUs
    An industrial computer compatible with MXM GPUs, used in factory AI and medical imaging.
    ### Banner: Corrosion-Resistant TPU Cable Assemblies
    M12 double-ended cable assemblies with stainless steel lock nuts, suitable for harsh industrial conditions.
    Banner TPU Kablo Setleri
    ### Siemens: Strengthened PCB Design and Testing by Acquiring ASTER
    PCB quality and time-to-market improved with "shift-left" DFT capabilities.
    ### Puls: 30% Better Efficiency and Reliability in DIN Rail Power Supplies
    The PLANET series of single and three-phase power supplies enhances performance.
    ### OnLogic: Palm-Sized Industrial PC for Edge Computing
    The CL260 model offers fanless, ultra-compact solutions for IoT and automation in limited spaces.
    ### Honeywell Performance+: Real-Time Data and Optimization in Guided Workflows
    Decision support for operators and workforce efficiency are being improved.
    ### Dold: RE 6900 Wireless Safety System
    A wireless solution for emergency stop and control in large robotic cells.
    ### Aerotech: Cost-Effective Two-Axis Laser Scanning Head
    The AGV-CPO CORE is an entry-level scanner for laser micromachining applications.
    ### Autotool: Automation Technology Day in Collaboration with KUKA
    An event featuring robotic demonstrations and insights from system partners held in Ohio.
    ### Omron DX100 Data Flow Edge: Device Simplifying Data Collection
    Connects to PLCs, sensors, and other automation equipment with a low-code environment.
    ### Yokogawa OpreX A8: Smart Edge Controller Focused on Data Flow
    Linux-based architecture enabling application reusability.
    ### AutomationDirect: Flexible Terminal Block Solutions for Control Panels
    The Konnect-It series offers space-saving options for cramped industrial cabinets.
    ### Teknic: Ethernet/IP Integrated Brushless Servo Motor
    The ClearPath-IP motor combines an EtherNet/IP servo drive and a high-resolution encoder.
    ### Siemens: Digital Twin Design Platform for the Industrial Metaverse
    Combines 2D and 3D digital twins with real operational data to support AI optimization.
    ### Altech: Extended GEOS Electrical Enclosures for Harsh Environments
    Ideal for outdoor use with IP67 protection and flexible mounting.
    ### SMC: New Sizes in Guided Cylinder and Clamp Flow Sensor Series
    New diameters in MGPK and PFUW products and measurement technologies without interference.
    SMC Genişletme
    ### Antaria: Ultra-Thin 5-Port Unmanaged PoE+ Gigabit Switch
    A compact switch for network and security applications in confined spaces.
    ### SMC: Updated Five-Port Directional Control Valve Series
    Added IP67 connectors and space-saving manifolds.
    ### Intesis 700 Series: Provides Support for Mitsubishi Controllers
    Offers HVAC data to BMS platforms without the need for an intermediary layer.
    ### Emerson: Enhanced DeltaV SaaS SCADA Mobile Access Features
    Improved remote monitoring and management capabilities in the cloud-based SCADA system.
    ### Patlite LR5-LAN LED Signal Towers with Ethernet/IP Models
    Direct network control and PLC integration are becoming easier.
    ### Lanner Electronics: Industrial PC for Edge AI Applications
    Real-time processing platform powered by NVIDIA Jetson Thor.
    ### Hidden Machine Vibrations with High-Frame-Rate Cameras
    Camera-based vibration monitoring reducing reliance on accelerometers in industrial environments.
    ### Carlo Gavazzi: Smart Industrial Energy Monitoring System
    Comprehensive energy management with cloud connectivity and local control panels.
    ### CES 2026: AI Robots, Sensors, and Collaborations
    Hyundai's humanoid robot strategy and other significant automation developments.
    ### Inbolt: Next-Generation Bin Picking with Robot-Mounted 3D Vision
    An intelligent solution for real-time 3D vision and fast picking.
    Inbolt Robotik Kutu Ayıklama
    ### Neura Robotics: Quadrupedal, Mini Humanoid Robots, and Neuraverse
    Introduced new commercial and industrial solutions, including a compact humanoid robot.
    ### Phoenix Contact and Forescout Collaboration
    Integration of edge networking and threat detection to secure converging IT/OT network systems.
    ### Neugart: Expanding Drive Portfolio with Software and Motion Systems
    Aims for more dynamic and efficient drive systems.
    ### Autonics VG2 Series Vision Sensors
    Compact and flexible inspection with integrated lighting and auto-tuning.
    ### Staubli TX2-60L MedX Ready: Precision Medical Robot
    Six-axis movement and hygienic design for operating rooms.
    Staubli Medikal Robot
    ### Aaeon: Computing Platforms for Industrial IoT and Edge AI
    Four new edge PCs and a series of fanless embedded box computers.
    ### AutomationDirect: Economical Photoelectric Sensors
    The AchieVe FBM series offers affordable and flexible object detection solutions.
