🏭 AI Readiness: Your Plant's True Potential! 🚀
    Artificial intelligence (AI) is increasingly becoming a topic of discussion in industrial operations. However, for many facilities, the real question should not be, "Which AI tool should we buy?" but rather, "Is our facility ready to use AI safely, beneficially, and in a way that provides a return on investment?"
    đź’ˇ AI: An Engineering Tool, Not a Replacement​
    For process control engineers, plant engineers, maintenance leaders, and operations personnel, AI should be viewed not as a tool that replaces process knowledge, but as an engineering tool that helps them make better decisions using existing data. A modern facility generates vast amounts of information through PLCs (Programmable Logic Controllers), DCSs (Distributed Control Systems), historian systems, laboratory systems, maintenance systems, production accounting tools, and ERP (Enterprise Resource Planning) platforms. The challenge is that this data is often fragmented, inconsistently named, poorly contextualized, or unreliable.
    AI is only as useful as the data, process understanding, and operational discipline behind it. A model that receives unreliable sensor data, misaligned lab results, missing operational context, or poorly managed asset information will produce unreliable recommendations. Before industrial facilities embark on AI initiatives, they must establish fundamental principles: reliable instrumentation, structured data, secure architecture, clear ownership, and disciplined validation.
    ⚙️ AI Readiness: More Than Just Buying Software​
    Many organizations approach AI primarily as a software acquisition. They evaluate vendors, compare features, and look for platforms that promise predictive maintenance, optimization, anomaly detection, or automated recommendations. While software is important, the limiting factor in the early stages of industrial AI projects is rarely the software itself.
    An AI-ready facility goes beyond merely having a historian and a set of process tags. It possesses a coherent data environment that connects equipment, process areas, production events, lab values, maintenance activities, and business outcomes. It has a control and network architecture that enables the secure transfer of operational data to analytical environments. It has engineering personnel who understand the process well enough to question the accuracy of model outputs. It has operators who trust the system because they were involved in its development, and it has governance systems that define how models are validated, monitored, modified, and retired.
    AI readiness requires multiple layers to work together.
    🎯 Start with the Decision, Not the Model!​
    One of the most common mistakes in industrial AI projects is to start with the model rather than the decision. Teams might begin by asking whether they should use machine learning, neural networks, generative AI, anomaly detection, or optimization algorithms.
    The first question should be: Which decision are we trying to improve?
    Once this decision is defined, the subsequent questions become clear: Who will use the output? How often is the decision made? What data is available before the decision is made? What is the economic value of making the decision better? What is the risk if the recommendation is wrong? Should the model recommend, warn, predict, optimize, or control?
    For projects at the beginning of an industrial facility's AI journey, most should focus on advisory or diagnostic AI rather than autonomous control. A model that predicts an abnormal condition, highlights a potential cause, or suggests an engineering review is much easier to validate and govern than a model that automatically changes setpoints. Closed-loop, AI-powered control may be appropriate in specific circumstances, but only after a facility has built strong data quality, cybersecurity, model validation, change management, and operator trust.
    • []Should we adjust fermentation conditions earlier?
      ]Is this batch likely to underperform?
      []Is this pump starting to fail?
      ]Is the dryer using more natural gas than expected?
      []Are we over-drying the DDGS?
      ]Is steam usage abnormal for the current production rate?
      []Is there a likelihood that a lab result will be out of target range before the sample is complete?
      ]Which asset should maintenance prioritize during the next shutdown?
    📊 Key Activity 1: Create a Data Inventory​
    Before building models, facilities should inventory their data sources. This doesn't have to be an academic exercise. It should be practical and driven by use cases.
    • []For a fermentation-related use case, the inventory might include fermenter temperature, pH, fill times, transfer times, agitator status, yeast propagation data, enzyme addition records, antibiotic usage, density or Brix data, lab results, CIP (Clean-in-Place) events, and batch start and end times.
      ]For a reliability use case, the inventory might include motor current, vibration, bearing temperatures, flow, pressure, run time, starts and stops, alarm history, work orders, maintenance notes, fault codes, and spare parts usage.
      []For an energy optimization use case, the inventory might include steam flow, natural gas usage, boiler data, dryer data, evaporator operation, production rate, cooling water, compressed air, ambient conditions, and equipment status.
    A useful data inventory should address:
    • ]Which systems contain relevant data?
      []Who owns each system?
      []Which process areas are covered?
      []Which tags are critical?
      []How far back does the data history go?
      []What data is missing?
      []Are engineering units documented?
      []Are timestamps reliable?
      []Can the data be exported or queried?
      []Are there known issues with bad values, frozen values, gaps, or outliers?
      []Can the data be accessed without compromising OT (Operational Technology) security?
    🔍 Key Activity 2: Contextualize Data​
    Raw time-series data is useful, but contextualized data is far more valuable. A historian might show a temperature increasing, a valve opening, or a flow rate changing, but AI models need to understand what these signals mean within the process.
    Contextualization links data to assets, process areas, operating modes, production events, and business outcomes. For a biofuel plant, this might involve mapping tags to fermenters, evaporators, dryers, centrifuges, pumps, tanks, boilers, cooling towers, and utilities. It also involves associating data with batch numbers, production campaigns, shifts, raw material lots, recipes, lab samples, CIP cycles, shutdown events, and maintenance work orders.
    Without context, AI can easily learn spurious correlations. For example, a model might interpret startup behavior as abnormal if startup periods are not tagged. It might confuse CIP conditions with production conditions. It might treat different recipes or raw materials as directly comparable. It might compare winter and summer operations without accounting for seasonal effects.
    Context also helps engineers validate model outputs. When a model detects an abnormal pattern, the engineering team needs to determine if the pattern represents a genuine problem, a known operating mode, a sensor issue, a maintenance activity, or a harmless process transition.
    Good contextualization doesn't require perfection at the outset. Facilities can start by selecting one process area and building a clean data model around the most important assets, tags, events, and KPIs (Key Performance Indicators).
    ⏰ Key Activity 3: Align Time Across Systems​
    Time alignment is one of the most underestimated requirements in industrial AI. Process historians, laboratory systems, maintenance systems, and production systems often represent time differently.
    A historian tag might be recorded every second. A lab result might be entered hours after a sample is taken. A work order might be opened after a problem is observed. A batch's official start time might differ from its actual start time.
    Consequently, to unlock the true potential of AI, facilities must not only invest in technology but also strengthen their fundamental data infrastructure and operational processes. This is the key to sustainable and valuable AI applications in the long run.
