Elif Özaksu
⚙️ 1. Siemens (S7-1200 / S7-1500 Series)
🔹 Origin: Germany🔹 Software: TIA Portal
🔹 Advantages:
- Very powerful and stable system architecture
- Integrated SCADA, HMI, and PLC development (TIA)
- Extensive spare parts and engineering support
- Profinet, Profibus, OPC UA, MQTT support
- High license cost
- Steep learning curve for beginners
⚙️ 2. Omron (CP / NX / NJ Series)
🔹 Origin: Japan🔹 Software: Sysmac Studio / CX-Programmer
🔹 Advantages:
- High-speed processor and motion control advantage
- Strong in robotic applications
- Integrated motion + vision system with Sysmac
- HMI design is simplified with IAG functions
- Technical support in Turkey is not as widespread as Siemens
- Some specialized modules are more expensive
⚙️ 3. Schneider Electric (Modicon M221 / M241 / M580)
🔹 Origin: France🔹 Software: EcoStruxure Machine Expert (formerly SoMachine)
🔹 Advantages:
- Multi-functional PLCs in a compact structure
- Ethernet/IP and Modbus TCP support
- Automation + energy efficiency integration
- Affordable solutions
- The software interface can be found confusing by some users
- Limited number of technical experts in Turkey
🧠 Which Brand Excels in Which Project?
| Application Type | Preferred Brand |
| Process Automation | Siemens |
| Robotics & Vision Systems | Omron |
| Compact & Energy-Focused Solutions | Schneider |
| High-Level Integration | Siemens / Omron |
📣 What Do You Think?
Which of these brands do you use, and are you satisfied?What advantages / challenges have you encountered?
