Methods to Achieve the Best Rate of Change in the PID Manipulated Variable
    Achieving the optimal rate of change for the manipulated variable in PID control loops is a critical issue for system performance and efficiency. This article, in light of the opinions of various automation experts, discusses how PID settings can be optimized, which methods can be used in control strategy, and how to intervene in special situations.
    ### Fundamental Strategies for PID Rate of Change
    Following Erik Cornelsen's question, the discussion revolves around how best to control the rate of change in the controller output when fast or slow changes are required. Some application examples include scenarios such as limiting large and sensitive valve movements, maintaining pipeline pressure stability, and managing steam loads operating in batches.
    ### Points to Consider in PID Settings
    • Not using or limiting the use of derivative provides smooth control.
    • Ramps or rate limiters added to the control signal can create incompatibility with PID tuning.
    • Applying a filter to the input signal offers a more stable and logical control experience.
    • Gradual output ramp functions should be used during critical processes such as startup, product transition, abnormal operation, and shutdown.
    ### Key Points Highlighted by Automation Experts
    • Greg McMillan: The type of measurement and installation need to minimize noise. PID should be supported by advanced techniques such as adaptive filtering and reset feedback with proper tuning.
    • Pat Dixon: Emphasizes that clearly defining the control objective means PID should be optimized according to process behavior, not simply with tight tuning.
    • Michel Ruel: Recommends using an appropriate filter time to reduce noise during PID tuning and avoiding unnecessary application of limits.
    • Peter Morgan: States that adding rate limiting to the PID output can lead to a delay in the change of the integral term, and therefore highlights the benefit of external reset feedback.
    ### Practical Solutions in Application
    • Reducing fluctuations by using ramp functions and automation procedures for controllers during startup and shutdown.
    • Dynamically changing PID tuning parameters according to operating conditions.
    • Applying adaptive tuning or different parameter sets when necessary.
    • Avoiding unnecessary use of limits and rate limiters.
    ### Conclusion
    To ensure the optimal rate of change for the manipulated variable in PID control loops, controlled tuning, a correct understanding of the process model, and the use of advanced techniques when necessary are important. By selecting PID settings appropriate for process characteristics and operating conditions in system design, both safe and efficient control are achieved.
    These comprehensive insights provide important resources for application and training in the field of PID control and automation.
