🚀 Industrial PoE Midspan: Powering Automation!
Elif Ă–zaksu
  • Altanlar
    Microchip Technology is bringing a breath of fresh air to the world of automation! With its new industrial-grade midspan, it simplifies power distribution in demanding production environments.
    ⚡ Both Power and Data with a Single Cable​
    Addressing the increasing needs of industrial automation and remote monitoring systems, the Microchip PD-9601GCI is a single-port midspan. This device eliminates installation complexity by transmitting both power and gigabit data over a single Ethernet cable.
    đź’Ş Designed for Harsh Environments​
    Compliant with the IEEE 802.3bt standard, this midspan supports up to 90W of power and 10/100/1000 Mbps data speeds. This ensures the smooth operation of high-power devices even in harsh industrial conditions. Furthermore, it simplifies installation in factory environments by eliminating the need for separate electrical outlets near edge devices.
    🛡️ Robust and Reliable Structure​
    Designed to operate in remote or heavy industrial areas, the PD-9601GCI features an IP30-rated sealed metal casing. This casing is resistant to vibrations and offers reliable performance across a wide operating temperature range from -40°C to 75°C. While providing power redundancy with dual DC power inputs (20V - 60V), its integrated industrial-grade surge protection safeguards connected equipment against voltage fluctuations.
    ⚙️ Easy Integration​
    It can be easily integrated into existing control panels with DIN rail, wall, or panel mounting options. This flexibility accelerates installation processes in industrial facilities.
    đź’ˇ Why Microchip PD-9601GCI?​
    • High Power Output: Up to 90W power transmission.
    • Wide Temperature Range: Operates between -40°C and 75°C.
    • Robust Design: IP30-rated metal casing and vibration resistance.
    • Wide Voltage Range: 20V - 60V dual DC input, compatible with 48V and 56V industrial battery systems.
    • Easy Installation: Power and data over a single cable, reducing the need for electrical outlets.
    Microchip's new product offers a reliable and efficient power solution for industrial automation and IoT devices, paving the way for future smart factories.
