ASRock Industrial has validated the AI BOX A395 hardware platform, which is compatible with the OpenClaw framework, enabling local, autonomous AI operations for enterprise and industrial applications.
### AI BOX A395 Hardware and Processor Specifications
- The compact AI BOX A395 is optimized for local AI inference with integrated acceleration, without cloud dependency.
- The hardware is suitable for automotive data ecosystems and general industrial areas requiring low latency.
- Processor: AMD Ryzen AI Max+ 395, an accelerated processing unit (APU) that combines CPU, GPU, and NPU architectures on a single silicon die.
- Processing power: With 126 Tera Operations Per Second (TOPS), large language models (LLMs) and computer vision tasks can be run in real-time.
- Thanks to these combined processing units, less power and space are required compared to separate graphics hardware.
### Memory and Connectivity Features
- High-frequency, up to 128GB LPDDR5x-8000 unified memory is used, which is critical for AI workloads.
- This allows the CPU, GPU, and NPU to access the same data pool without latency.
- Input/output features:
- USB4 ports for high-speed connection to external sensors and storage devices.
- Dual storage slots, providing backup or high-capacity configuration options for large model libraries.
### Industrial Durability and Integration
- The AI BOX A395 operates quietly and stably with an advanced thermal management system for continuous 24/7 use.
- Compatible with frameworks like OpenClaw that automate enterprise workflows.
- Thanks to Windows and Linux support, it can be easily integrated into existing IT infrastructures.
- With local installation, sensitive data remains within the corporate firewall, meeting high security requirements.
This platform offers a powerful and reliable hardware solution for businesses looking to move AI agents from experimental stages to production environments.
