Grounding & Surge Protection – Fundamental Elements of Safety in Electrical Installations
zedmuhendislik
  • Zed Mühendislik
    Ensuring safety in electrical installations is not possible solely through correct wiring or the use of quality materials.
    There are two fundamental elements that protect the continuity of the system and human life: earthing (grounding) and surge protection systems.
    When these two components work together, electrical accidents and equipment damage are largely prevented.
    In this article, we will examine what earthing and surge protection systems are, how they work, and why they are complementary structures.
    🔹 What is Earthing?​
    Earthing is a system that ensures leakage currents that may occur in electrical installations are safely transmitted to the ground.
    The aim is to protect people and equipment from possible electric shocks or high potential differences.
    An earthing system typically consists of conductive rods (electrodes) buried in the ground and conductive lines connected to these electrodes.
    In the event of a fault, the leakage current flows through these lines to the ground, which is the path of least resistance, and the danger is eliminated.
    An earthing system that is not properly installed or periodically tested can pose hidden risks in electrical installations.
    Therefore, it is a requirement for businesses to have annual earthing measurements carried out, in accordance with both the Occupational Health and Safety Regulation and the Electrical Internal Installations Regulation.
    🔹 What is a Surge Protector?​
    A surge protector is a device that protects an electrical system against sudden voltage increases.
    High voltage surges, especially those caused by lightning strikes or grid fluctuations, can cause serious damage to devices.
    The surge protector ensures system safety by diverting this sudden voltage to the ground.
    In short:
    • When lightning or a sudden voltage surge occurs → The surge protector activates.
    • It transfers the voltage to the ground → Electronic devices and the system are not damaged.
    • After the danger passes → It returns to normal operation.
    Surge protectors are generally used in panel inputs, transformer centers, energy monitoring systems, and communication lines.
    🔹 The Connection Between Earthing and Surge Protection​
    The healthier the earthing system, the more effectively the surge protector works.
    This is because the primary function of the surge protector is to transfer excess voltage to the earth line.
    If the earthing resistance is high, the energy on the surge protector cannot discharge quickly enough, and system protection is weakened.
    Therefore, both systems must be designed together and tested regularly.
    Let's explain with an example:
    In regions with a high risk of lightning, such as Antalya, the use of surge protectors is critically important, especially in industrial facilities or hotel complexes.
    However, no matter how powerful the surge protection system is, if the earthing measurement is insufficient, the lightning current cannot be effectively discharged.
    As a result, devices can still be damaged.
    Therefore, for effective protection, the following rule applies:
    "A powerful surge protector cannot fully perform its duty without solid earthing."
    🔹 Importance of Periodic Measurement and Maintenance​
    Earthing and surge protection systems should not be forgotten after installation.
    Over time, earth resistance changes, connections loosen, or electrodes oxidize.
    Similarly, surge protectors lose their effectiveness after a certain number of strikes.
    Therefore, the following procedures should be carried out at least once a year:
    The advisory notes included in the reports prepared as a result of these measurements actually represent mandatory criteria to be implemented by the employer.
    These warnings must be taken into account for the safety of the facility.
    🔹 Earthing and Surge Protection Measurement Services in Antalya​
    ZED Mühendislik is a company based in Antalya, specializing in earthing measurement, electrical tests, and surge protection system controls.
    All our services comply with TSE, OHS, and Electrical Internal Installations Regulation standards.
    We provide regular measurement services in Antalya Organized Industrial Zone (OSB), as well as hotels, factory facilities, business centers, and residential complexes.
    All measurements performed with our calibrated devices are documented with engineer-approved reports valid for official inspections.
    🔹 Conclusion​
    Earthing and surge protection systems are the unseen but most vital parts of an electrical installation.
    Regular inspection of these two systems protects not only devices but also human life.
    For businesses in Antalya looking for safe, certified, and professional services, ZED Mühendislik is always the right address with its experience and engineering approach.
    Source: ZED Mühendislik
