SĂĽeda Asil
Innovative Solution from Nabtesco: Super Short Actuators
Nabtesco has introduced its new Super Short Actuators as a solution to the challenges of limited installation space and strict weight restrictions encountered in robotic and mechanical engineering applications. These innovative actuators combine Nabtesco's cycloidal gear technology with ALVA's compact GearTorq frameless motors, offering a structure that is approximately 30% shorter and 30% lighter than comparable standard models.
High Performance and Compact Design
Super Short Actuators provide high power density, high peak torques, and backlash-free force transmission, while functioning as a plug-and-play system that reduces design and integration effort. In each actuator, the gear, motor, bearings, and encoder are integrated to work in harmony for optimal performance.
Optional GaN-Based Motor Control
To fully unleash the motor's performance, Nabtesco offers the Rapid Control Prototyping (RCP) PANTHER platform, developed by Nabtesco Group company adcos. This platform includes two redundant 3-phase high-current MOSFET power stages, as well as a 3-phase gallium nitride (GaN) power stage paired with motor-specific control software to drive the GearTorq frameless motor.
Target Applications for Lightweight and High-Dynamic Axes
The high power density of Super Short Actuators enables slender, high-performance axes and joints, especially where axial installation space is limited, strict weight requirements apply, and high dynamics such as cyclic loads and varying motion profiles are needed. Mobile and battery-powered systems also benefit from the lower weight and the resulting reduction in moving masses. Typical applications include:
- Humanoid robots
- Cobots (collaborative robots)
- Exoskeletons
- Delta robots
- Lightweight, high-dynamic robot axes
- Pan-tilt systems
Modular Configurations and Digital Sensing
Built on a modular architecture, these precision actuators cover a nominal torque range from 7 to 178 Nm. Options include a hollow shaft for internal cable and supply line routing, a dual encoder, and a digital cycloidal gear that captures operating and status data to support early wear detection and predictive maintenance.
German Manufacturing and Quality Standards
Production takes place at Ovalo GmbH's facility in Limburg (Lahn), Germany, under IATF 16949 certification, in accordance with automotive quality standards. This ensures full traceability, short development cycles, and high quality, safety, and reliability from single-piece flow to high-volume series production.
A Powerful Solution for Future Robotic Designs
Daniel Obladen, Director of Sales and Marketing at Nabtesco Precision Europe GmbH, states that the need for integrated drive concepts is increasing in the face of growing demands for dynamics, installation space, and weight. He adds that Super Short Actuators enable the realization of robot and machine designs that were previously only possible with significant design compromises, by offering less installation space, less weight, high power density, integrated cable routing, and digital functions in a single solution.
