A New Era in Industrial Networks: Wi-Fi 6E from Phoenix Contact
Wireless networks on factory floors are increasingly strained due to heavy traffic between autonomous vehicles (AGVs, AMRs) and connected machines. Congestion, especially in the 2.4 GHz and 5 GHz bands, can lead to delays and connection drops, disrupting mobile processes. Phoenix Contact offers the FL WLAN 2350 access point as a solution to this problem. This device supports the Wi-Fi 6E standard, opening up the less congested 6 GHz frequency band for use.
Why is the 6 GHz Band Important for Industrial WLAN?
Wi-Fi 6E extends the IEEE 802.11ax (Wi-Fi 6) standard to the 6 GHz band. This new spectrum provides additional radio resources as it is not shared with older Wi-Fi devices. According to Phoenix Contact, these additional channels reduce interference and improve network performance, especially in applications requiring high availability and real-time capabilities.
This is of great importance for manufacturing and intralogistics operators. Mobile systems that depend on a continuous and predictable data connection may have to stop if they lose connectivity, which directly affects efficiency and process stability.
Application Areas: Intralogistics and Manufacturing
Phoenix Contact identifies AGVs, AMRs, warehouse shuttles, and radio-based machine connections as typical application areas. In these scenarios, the access point acts as a wireless bridge between mobile or difficult-to-wire equipment and the facility's wired Ethernet infrastructure. Wireless machine connections can also reduce cabling effort for moving machine parts and frequently reconfigured production lines.
Technical Specifications of the FL WLAN 2350
- Data Rate: WLAN data rates up to 2,400 Mbit/s.
- Ethernet Port: Gigabit Ethernet port with Power over Ethernet (PoE) support. This provides both power and data over a single cable, simplifying installation.
- Protection Class: IP65 protection class, resistant to dust and water jets, allowing direct installation in industrial environments without the need for an additional enclosure.
Profinet, Profisafe, and Fast Roaming for Mobile Automation
The access point supports Layer 2 communication for Profinet and Profisafe for automation applications. This enables controllers and field devices to exchange cyclic process data and safety-related telegrams over a wireless connection, just as they would with a wired connection. Fast roaming allows mobile clients to switch between access points with minimal interruption, which is vital for vehicles moving in large production halls and warehouses.
Cybersecurity According to IEC 62443-4-1
The FL WLAN 2350 has been developed in accordance with IEC 62443-4-1, the international standard that defines secure product development lifecycle requirements for industrial automation components. This ensures that the device meets regulatory requirements such as the Radio Equipment Directive (RED) and the Cyber Resilience Act (CRA). For machine manufacturers and plant operators supplying products to the European market, compliance with these regulations is becoming a prerequisite for connected wireless equipment.
