🚀 Revolutionizing 3D Project Generation from Eplan: Automated Panel Design!
Elif Özaksu
  • Altanlar
    💡 Eplan Takes Automation in Engineering to the Next Level​
    Eplan has announced a groundbreaking innovation in engineering automation: automated project generation in 3D! This allows assembly panel layouts to be created for the first time using rule-based engineering. With Eplan Platform 2027, the automatic and rule-based generation of 2D schematics is extended to 3D control panel layouts in Eplan Pro Panel.
    ⚙️ One-Click Transition from 2D to 3D​
    Devices can now be automatically assigned to predefined DIN rails based on control panel templates and placed in the installation space. This creates a digital twin of the control panel with a single mouse click. Holger Jansen, Eplan Owner, states, "With the automatic generation of the control panel's digital twin, we have reached a milestone in our automated engineering strategy." This innovation means increased efficiency and quality in planning and production processes for Eplan users.
    ⚡ Faster Results, Less Effort​
    The core of this new approach is that users utilize 3D macro technology in Eplan Pro Panel instead of copying and pasting templates. The typical structure in existing automated project generation has been expanded with a new object: "Layout Space Type." Users do not need any programming knowledge, and the configuration interface is generated automatically.
    🎯 Easy Selection and Automatic Positioning with Templates​
    Eplan Platform 2027 takes another significant step in engineering automation. Standardized layouts can be automatically generated based on existing control panel layouts. Based on current templates containing mounting rails, devices are automatically assigned to defined DIN rails and placed during the production process. Different control panel variants and mounting rail configurations can be easily saved as personalized templates and selected according to the required configuration. This functionality is ideal for the rapid implementation of standardized control panels. Components such as circuit breakers or rail terminals are automatically positioned, significantly reducing the engineering workload for manual placement and other repetitive routine tasks.
    📏 Rules Provide Clarity and Structure​
    The process is quite simple: Users create a basic layout for a control panel, including cable ducts, in Eplan Pro Panel and define the installation spaces and their geometries. Then, they import the bill of materials for electrical components such as terminals, motor overload switches, PLC components, and fuses. Based on a 3D macro of a control panel that is not yet populated with components, the software places the devices on the panel using simple rules.
    ☁️ Easy Cloud Collaboration and Integrated Processes​
    Automated project generation is an application of the Eplan Cloud. This offers users all the collaboration advantages for engineering across multiple locations without needing additional funds for extra IT applications. More importantly, users do not need in-depth configuration knowledge; they only need to master the basic principles of using macro technology.
    This also simplifies the overall engineering process. 3D modeling is integrated into macro creation as part of engineering. Furthermore, this optimized process allows for earlier transfer of production data. Eplan Smart Production then supports the physical assembly of the mounting panels.
    The advantages are clear: greater end-to-end data consistency, increased ease of use, and faster, higher-quality results.
