Ahmet Ă–.
ENEMAC Couplings Developed for High-Speed Automation
In highly dynamic drives, especially in applications requiring high rotational speeds, rapid acceleration cycles, and precise positioning, severe mechanical demands are placed on drive system components. ENEMAC offers two specialized coupling series designed to meet these needs: the EWS metal bellows coupling and the EWE elastomer coupling.
Both series are rotationally symmetrical, dynamically balanced, and engineered marvels specifically for high-speed automation. They ensure backlash-free torque transmission, low moment of inertia, and high concentricity, supporting smooth and accurate motion sequences even at high speeds.
EWS Metal Bellows Coupling: For Maximum Torsional Rigidity
- Speed Capacity: Rated for rotational speeds up to 57,000 rpm.
- Features: Backlash-free torque transmission, compensates for axial, radial, and angular shaft misalignments.
- Low Inertia: Supports rapid acceleration and deceleration profiles due to its low mass moment of inertia.
- Mechanical Stability: Ensured by permanent micro-plasma welding between the hub and the bellows.
- Available Sizes: Available in 6 different sizes, for nominal torques from 25 to 700 Nm and shaft diameters from 5 to 60 mm.
EWE Elastomer Coupling: For Vibration Damping and Electrical Isolation
- Speed Capacity: Designed for rotational speeds up to 35,000 rpm.
- Features: Combines vibration and shock damping with dynamic responsiveness.
- Misalignment Compensation: High-strength polyurethane elastomer spider compensates for axial, radial, and angular misalignments.
- Electrical Isolation: Provides electrical isolation between shafts.
- Safety: Offers additional operational safety with redundant torque transmission in case of elastomer spider failure.
Coupling Selection Based on Automation Drive Requirements
From robotic joints to gantry axes, and from CNC machine spindles to positioning systems, both series ensure reliable power transmission under high dynamic loads across a wide range of applications. Machine manufacturers can choose the EWS when maximum torsional rigidity and speeds up to 57,000 rpm are critical, and the EWE for applications where vibration damping and electrical isolation are also required.
Additional Information: Torsional Rigidity and Dynamic Balancing in High-Speed Servo Drive Systems
In precise servo drives and high-speed CNC spindles, torsional rigidity determines how accurately rotational motion and encoder feedback are transmitted to the motor and load without angular deviation or resonant oscillation. Metal bellows couplings combine high torsional rigidity with low radial and angular restoring forces, minimizing radial bearing loads on adjacent motor and gearbox shafts.
At rotational speeds exceeding 30,000 rpm, even the smallest asymmetric mass distributions generate centrifugal forces that cause bearing vibration and positioning errors. Rotationally symmetrical double-sided conical clamping hubs clamp concentrically around the shaft without keyways, thereby eliminating the mass imbalance inherent in keyed connections and maintaining dynamic balance during high-speed acceleration ramps.
