✨ Next-Generation 3D Sensors from wenglor: Revolutionizing Robotics and Quality Control! ✨
    🚀 wenglor's M3DS Series: Factory-Calibrated 3D Sensors on the Market!​
    wenglor sensoric group has expanded its machine vision portfolio by introducing factory-calibrated 3D sensors that internally calculate point clouds and can be integrated into robotic cells via GenICam. The M3DS series, with 5 and 12-megapixel camera resolutions, captures the shape, position, and height of objects in detailed 3D point clouds.
    🎯 Stripe and Phase Methods: Measurement for Every Task​
    M3DS sensors use either the stripe or phase method, depending on the measurement task:
    • Stripe Method: Provides robust data for reflective metal surfaces or short exposure times.
    • Phase Method: Maps the finest height differences and surface structures.
    In addition to the 3D point cloud, the sensor also provides a confidence image indicating the quality of each measurement point and an intensity image of the surface reflection. Integrated filters reduce data volume and simplify processing by removing irrelevant measurement points. Two different model options are available for small and large measurement volumes.
    ⚙️ On-Sensor Processing and Industrial Design​
    Since all point cloud calculations occur within the sensor, external computer hardware requirements are very low. Active cooling with an integrated fan keeps the sensor at operating temperature, while robust mechanics and optics deliver reliable results despite vibrations on the robotic arm and machine movements. The IP67 protection rating ensures protection against dust, dirt, and temporary water ingress, and thanks to factory calibration, full measurement accuracy is achieved immediately after initial startup.
    💡 Presets and Auto-Adjustment for Easy Start-Up​
    The auto-adjustment feature automatically adapts recording parameters to the captured scene. Predefined settings are available for dark, reflective, and transparent objects, as well as presets for high accuracy. This makes it possible to start 3D image processing without extensive expert knowledge. The wenglor Vision Viewer allows for the adjustment of all relevant sensor parameters and the visualization of 3D point clouds.
    🔗 GenICam Integration: Compatibility with Robotics and Machine Vision Software​
    Thanks to the GenICam standard and an SDK for C++ and Python on Windows and Linux, M3DS sensors can be integrated with software from different manufacturers, such as MVTec HALCON or NeuroCheck. Calibration examples prepared for bin picking, pick-and-place, and robot guidance, hand-eye calibration, and sample projects are available on GitHub.
    🔍 Technical Comparison: Zivid 2+ M130 vs. wenglor M3DS​
    While the Zivid 2+ M130 offers 5 MP resolution, an 80-200 cm working range, IP65 protection, and a weight of 1,000 g, the M3DS series stands out with a 12 MP option in addition to 5 MP, and IP67 protection. This indicates that wenglor provides higher resolution and better environmental protection.
