Elif Özaksu
⚙️ A New Era in Automotive and Industrial Manufacturing
In automotive and industrial sheet metal production, the absence of weld nuts is often discovered in the final stages of assembly. This leads to rework or scrap costs, while manual inspections slow down production. Contrinex offers an innovative solution to this problem: a plug-and-play Smart Nut Detection Sensor that automatically verifies the presence of weld nuts on welding lines.
🔍 Automatic Nut Presence Verification in Welding Cells
This sensor non-contactually detects the presence or absence of weld nuts, preventing missing components from progressing down the production line. It covers nut sizes from M5 to M12. It can be used before welding to ensure correct nut positioning with centering pin accessories, or after welding to verify the nut's presence.
🛡️ Robust Design Against Welding Spatter
Welding environments expose sensors to spatter and heat. The Smart Nut Detection Sensor uses a robust Full-Inox stainless steel housing with Contrinex's ActivStone anti-spatter coating. Its M12 threaded body and 4 mm diameter sensing pin are designed for reliable detection in heavy-duty applications.
💡 Pre-configured Thresholds and IO-Link Integration
The sensor offers two pre-configured switching thresholds to distinguish between metal sheets with and without weld nuts in most standard applications. This allows it to be installed without parameter adjustment. When special settings are needed, the integrated IO-Link connection allows switching thresholds to be configured and adjusted via teach commands. Based on Contrinex Smart Sensor Technology, the sensor also provides timers, alarms, and counters. Digital measurement values can be read via IO-Link for integration into networked production systems.
🚀 Operational Benefits
- Automated verification reduces manual inspections, defective parts, and production downtime.
- Combining multiple functions in a single sensor helps reduce spare part variety and simplifies procurement.
- IO-Link allows threshold changes for different sheet materials or nut sizes to be written from the controller without manual adjustment on the sensor.
