🛠️ A Critical Resource in Production: Compressed Air
Compressed air, one of the most commonly used auxiliary resources in the manufacturing sector, is also one of the most energy-intensive systems. As businesses grow, these demands change. Bobcat Company is expanding its industrial air portfolio with new tank-mounted, fixed-speed, and extra-large efficient air compressor models for a wide range of applications, from small workshops to large industrial facilities, including woodworking, metal fabrication, light manufacturing, and automotive services.
📈 Compressed Air Supply According to Changing Demand
While an inadequate compressor restricts production, a large machine operating below its capacity leads to energy waste. For growing businesses, the ability to incrementally increase capacity and coordinate multiple compressors is more important than the performance of a single unit. Bobcat's expanding product range addresses this need with various airflow options in both its small and large models and multi-compressor networking capabilities.
⚙️ Tank-Mounted Compressors for Workshops
The new SA7.5T and SA7.5TD tank-mounted models are designed for workshops where space, power access, and easy installation are important. The triple-voltage, plug-and-play design simplifies installation. Systems can be expanded by connecting multiple compressors, and the automatic power restart function helps reduce downtime after power outages.
🏭 Two-Stage Compressors for Industrial Facilities
For larger businesses, Bobcat offers the EA125, EA150, EA200, EA250, EA300, and EA400 fixed-speed efficient air compressors, in addition to its existing EA250VS, EA300VS, and EA400VS variable-speed models. The EA125, EA150, and EA200 feature compact, base-mounted designs that save space. Integrated interstage cooling, advanced separation technology, an aftercooler, and an efficient two-stage compressor unit work together to optimize performance and support long-term system reliability. In two-stage compression, air is compressed in two steps with cooling in between, which reduces the work required to reach the final pressure compared to single-stage compression.
🧠 Smart Controls and IE4 Motors
Models from EA250 to EA400, in both fixed-speed and variable-speed versions, combine intelligent system controls with an IE4 energy efficiency class motor and a two-stage compressor unit to reduce energy consumption without sacrificing output. Variable-speed models offer adjustable pressure settings from 100 to 175 psi for precise control across a wide range of operating requirements. Advanced controls allow multiple compressors to operate as a connected network, automatically balancing load demand to increase efficiency and minimize energy waste, while a variable-speed cooling system maintains optimal operating conditions to protect critical components and extend equipment life.
🛡️ Warranty and Service Support
All newly introduced models and other Bobcat industrial air products are covered by a comprehensive five-year warranty and backed by US-based parts and service support. Patrick Jakeway, General Manager of Bobcat Company Industrial Air, stated, "By expanding both our tank-mounted and industrial air offerings, we are providing customers with greater flexibility to choose solutions that fit their specific application needs."
💡 Additional Information
IE4 refers to the Super Premium efficiency class defined in IEC 60034-30-1 for electric motors. Since energy constitutes the largest share of a compressor's lifetime cost, motor efficiency, multi-unit load management, and the avoidance of partial load operation are key selection criteria for industrial compressed air systems.
