🚀 New Generation Motion Technologies and KinetiMax Housed HPD from Allient at SPS 2026!
  • Dokuz EylĂĽl Ăśniversitesi
    🌟 Innovative Solutions at SPS 2026​
    Allient showcased its latest custom motor, motion, control, and power technologies at SPS (Smart Production Solutions) 2026 in Nuremberg, from November 24-26, at booths #241 and #340 in Hall 1. The company introduced the new KinetiMax™ Housed HPD Series from its Allied Motion line. This series combines KinetiMax™ Frameless HPD motor technology with an integrated housing, shaft, and bearing package, offering high torque density and simplified mechanical integration.
    ⚙️ Motor and Drive Portfolio on Display​
    Allient presented a wide range of motion control solutions under its Allied Motion and Heidrive product lines:
    • KinetiMax™ Precision Series: Compact, high-performance motors designed for precision motion applications requiring accuracy, reliability, and design flexibility.
    • KinetiMax™ Frameless HPD Series: High power density, outer rotor brushless motors supplied as frameless rotor-stator part sets.
    • KinetiMax™ Housed HPD Series: A complete motor solution providing exceptional torque density and simplified integration with an integrated housing, shaft, and bearing package.
    • HeiTronX Servo Motors with Integrated Electronics: Motor, encoder, and electronics combined in a single compact unit for decentralized automation architectures.
    • Stainless Steel Servo Motors for Hygienic Applications: Durable, easy-to-clean stainless steel servo motors designed for washdown and hygienic environments.
    đź’ˇ Live Application Demos​
    The Allient booth featured several working prototypes and application demos illustrating real-world mechanical packaging and system integration:
    • Wheel drive modules using KMF062 with an integrated gearbox, and KMF072 combining an integrated gearbox, integrated electronics, and brake.
    • A SIM racing seat prototype powered by a KinetiMax™ HPD motor in conjunction with a strain wave gearbox.
    • A 360° LED status ring integrated into HeiTronX HTB and HTS product lines to provide instant visual operational feedback and simplify troubleshooting.
    The frameless motor demos showcased design flexibility, reduced package size, and optimized performance in robotics and mobility applications. Helmut Pirthauer, Allient Vice President and Group President, stated that SPS was a key platform to present the new KinetiMax™ Housed HPD Series alongside the company's extensive motion portfolio.
    🔍 Outer Rotor Frameless Motors and Strain Wave Gears​
    In outer rotor brushless permanent magnet motors, the permanent magnets are mounted into a rotating outer bell that surrounds a stationary internal copper-wound stator. Since electromagnetic torque is proportional to the square of the air gap radius, placing the magnetic air gap close to the outer circumference of the motor provides significantly higher continuous and peak torque within a short axial length compared to conventional inner rotor designs. Supplying these arrangements as frameless rotor-stator sets allows machine builders to mount them directly onto existing mechanical shafts – eliminating couplings and reducing overall drivetrain length – whereas housed variants provide pre-aligned precision bearings for quick plug-and-play assembly.
    When paired with strain wave (harmonic) gearboxes in robotic joints or compact wheel drives, high torque density motors achieve high single-stage reduction ratios (typically 50:1 to 160:1) with virtually zero backlash. Meanwhile, decentralized servo motors with integrated drive electronics and 360-degree status LEDs reduce control cabinet size and multi-conductor motor cabling, allowing maintenance technicians to visually identify drive fault conditions on the factory floor without connecting diagnostic software.
