🚀 Belden Simplifies IT/OT Convergence at SPS 2026!
Belden Facilitates IT/OT Convergence from Machine to Enterprise Level at SPS 2026​
Belden Inc. showcased how manufacturers can simplify IT/OT convergence by connecting industrial assets, segmenting data flows, and securing operations from the machine to the enterprise level at the SPS 2026 exhibition in Nuremberg from November 24-26. Under the theme "From Machine to Enterprise – Connect, Segment, Protect," the company highlighted practical edge artificial intelligence (AI) and generative AI (GenAI) applications, along with joint demonstrations for both new installations and existing plant upgrades.
Unlocking Locked Machine Data in Existing Plants​
As industrial enterprises merge information technology (IT) and operational technology (OT) networks, the operational data required for real-time automation and analytics often remains isolated within individual machines via disparate industrial protocols. Belden's exhibit focused on transforming these raw machine tags into secure, actionable insights without requiring disruptive equipment changes.
Aurélien Fabre, Managing Director of Belden EMEA, stated that industrial transformation begins not with replacing existing functional equipment, but by unlocking the data already present across operations and transforming it into faster, smarter decisions. Fabre emphasized that this is where connectivity, security, and AI can create real value, adding that IT/OT convergence is no longer a future goal but a present reality that is reshaping how industrial operations create value.
Edge Computing, RUCKUS Wireless Integration, and AI Diagnostics​
At the machine level, Belden introduced a new software-defined IP67 edge platform that integrates sensing, data contextualization, decision-making, control, and connectivity. The platform supports both existing plant upgrades and new designs by machine builders, as it can be deployed in existing machines without changing control codes.
On the wireless side, Belden showcased flexible antenna solutions, edge services, and high-performance coverage for fast-paced industrial and warehouse environments. This was the first time they exhibited together with RUCKUS Networks, which joined the company in July, at SPS. At the booth, RUCKUS wireless access points were directly integrated with Belden's robust wired infrastructure for plant and warehouse automation. The jointly planned wired and wireless network requires less hardware, closes coverage gaps including warehouse racks, and can be deployed faster.
Belden also introduced Digital Coworker, an AI assistant designed for OT network troubleshooting. By analyzing live network topology and device configurations, this tool enables engineers to isolate the root cause of network failures in minutes instead of days, using simple language queries.
Additional Booth Highlights and Ecosystem Demonstrations:​
  • Decentralized Safety and Multi-Protocol Data Acquisition: LioN-Safety I/O modules for decentralized machine connectivity and functional safety, paired with the Digital Data Highway to collect data from over 300 industrial protocols at the edge without requiring coding.
  • Robust Switching and OT Cybersecurity: Scalable Layer 1 to Layer 3 infrastructure including Hirschmann GREYHOUND GRS2000 and GRS105/106 robust switches for industrial backbone and edge aggregation, along with the IAF-240 industrial firewall and Belden NAC (network access control) for network segmentation and OT security.
  • Joint AI and Digital Twin Applications: Hybrid manufacturing zone edge AI developed with AWS and Reply, keeping production data on-premises; digital twins for asset condition monitoring with Bosch Digital Twin Industries; and GenAI-powered analytics for production performance and energy compliance with Edge2Web.
IT/OT Network Segmentation and Software-Defined Edge Contextualization​
In modern industrial facilities, directly connecting legacy operational technology (OT) controllers like PROFINET, EtherNet/IP, or Modbus to enterprise IT networks exposes critical production machines to cyber threats and broadcast storm traffic. Implementing industrial firewalls and Network Access Control (NAC) compliant with IEC 62443 standards segments the plant floor into isolated security zones and conduits, ensuring that only authorized, encrypted telemetry passes upstream while preserving deterministic real-time control loops.
At the machine edge, software-defined IP67 gateways separate data acquisition from deterministic control execution. By passively querying or listening to sensor and controller signals and transforming raw register addresses directly into structured, semantic data models (such as OPC UA or MQTT payloads) within a robust, machine-mounted enclosure, manufacturers avoid the costly and risky process of rewriting validated PLC ladder logic on legacy production lines.
