🚀 Seamless Automation with CODESYS Redundancy: High Availability Solution from Weidmüller!
    ⚙️ Continuous Operation in Industrial Processes​
    Industrial production lines, energy infrastructures, and critical process facilities can experience significant cost and operational losses due to PLC failures or planned maintenance. Traditionally, fault-tolerant controller redundancy required expensive and closed hardware ecosystems. This prevented machine builders from integrating modern edge analytics or third-party software containers onto the same control platform. Open edge controllers, on the other hand, often lacked the deterministic dual-CPU failover capabilities necessary to sustain continuous operation at single points of failure.
    💡 An Innovative Approach from Weidmüller​
    To overcome these reliability and architectural challenges, Weidmüller offers a solution that combines robust, high-performance industrial controllers with an open Linux-based operating system and standardized IEC 61131-3 software redundancy.
    🔄 Synchronized Dual-Controller Failover Architecture​
    At SPS 2026, Weidmüller introduced its redundant control solution at the CODESYS booth, synchronizing u-control M4000 controllers running on u-OS with CODESYS Redundancy SL. This architecture links two high-performance u-control M4000 controllers into a synchronized, fault-tolerant control system.
    During continuous operation, CODESYS Redundancy SL synchronizes control instances between the primary and standby u-control M4000 units. If the active controller experiences a failure or requires planned maintenance, the software coordinates an instantaneous switchover to the healthy standby unit, minimizing downtime and ensuring uninterrupted process execution.
    🌐 Open Software Extensibility and Scalable Engineering Workflows​
    Built upon the open u-OS software platform, this architecture extends beyond standard deterministic PLC execution. Users can deploy Weidmüller applications, third-party software containers, and custom user modules directly onto the controller hardware, alongside the CODESYS runtime. This modular approach allows automation engineers to add data acquisition, edge analytics, cloud communication, and device management functionalities without redesigning the core control system.
    Designed for applications requiring high availability and predictable maintenance windows, this solution preserves familiar CODESYS engineering workflows in redundant topologies, enabling OEMs and plant operators to seamlessly scale existing application code to fault-tolerant deployments.
    🔍 Technical Details and Competitive Analysis​
    In industrial PLC redundancy according to IEC 61508 and IEC 61131-3 automation standards, software-based hot-standby architectures like CODESYS Redundancy SL synchronize process images, persistent variables, and task states between two identical CPU nodes over high-speed Ethernet connections, without requiring specialized optical synchronization modules.
    Running on Weidmüller's Linux-based u-OS (which supports Docker encapsulation with real-time RT-Preempt kernel scheduling) and the quad-core u-control M4000 hardware platform, the system isolates deterministic control tasks from non-real-time IT/OT edge workloads, while maintaining seamless failover to redundant fieldbus I/O (such as PROFINET S2/R1 or EtherCAT cable redundancy).
    In the open-architecture redundant PLC market, Weidmüller's u-control M4000 and CODESYS Redundancy SL solution directly competes with Phoenix Contact's PLCnext Technology redundant controllers (like the RFC 4072R), WAGO's PFC200/PFC300 redundant CODESYS controllers, Beckhoff's TwinCAT 3 Controller Redundancy, and Siemens' SIMATIC S7-1500R/H fault-tolerant systems. While the Siemens S7-1500H offers hardware-synchronized lockstep redundancy for large process plants within a closed TIA Portal ecosystem, Weidmüller differentiates itself by combining open Linux container extensibility via u-OS with standardized CODESYS Redundancy SL, offering a vendor-agnostic path to high-availability automation for mid-sized machine builders and infrastructure operators.
