Cengiz Ă–zemli
Uncovering Hidden Losses with Production Data
While manufacturers collect massive amounts of operational data, translating this information into meaningful improvements isn't always easy. Even though existing systems provide visibility into equipment performance and process conditions, many facilities struggle to connect this information to opportunities to reduce costs or increase efficiency.
A North American Manufacturer's Story: Million-Dollar Loss
For one North American manufacturer, a closer look at existing process data uncovered between $1 million and $1.1 million in annual product loss on a high-speed filling line. The operation was meeting production targets, but variations in individual filling head performance were creating losses that went unnoticed with traditional reporting.
This project demonstrates how manufacturers can move beyond monitoring performance to identify and quantify opportunities for improvement.
Starting with the Business Challenge: Problem-Focused, Not Technology-Focused
When manufacturers consider advanced analytics or AI, it's easy for the conversation to focus on technology before the problem is fully understood. But determining where to invest begins with understanding the operational challenge and what solving it could mean for the business.
This project used an approach to examine existing production data, identify opportunities for improvement, and quantify their potential value before embarking on larger investments. In this application, the manufacturer wanted to understand if they could reduce product loss without compromising filling weight requirements.
High-speed filling operations must account for variations in equipment behavior and process conditions. To prevent underfilling, manufacturers often operate above minimum weight requirements. While some margin is necessary, consistently dispensing more product than required creates costs that can quickly accumulate.
The challenge was to determine how much loss could realistically be reduced and what factors were contributing to the losses.
Looking Beyond Line-Level Averages
The filling line included 32 individual filling heads, each subject to differences in mechanical condition, operating parameters, and process variability.
While overall line performance appeared acceptable, aggregated reporting made it difficult to pinpoint which heads were consistently overfilling or behaving differently than others.
The team analyzed 5.1 million fills and transformed over 100 historical tags into structured datasets aligned with individual filling cycles. This required reconstructing operating events, normalizing timestamps, and linking process measurements to specific filling heads.
Machine learning models were then developed for each head, incorporating variables such as fill time, flying weight, product density, flow rates, temperature, and pressure.
The models achieved R² values greater than 0.90, indicating a strong fit between predicted and observed outcomes in the analyzed data.
By examining individual equipment behavior, the team was better able to understand process variability, identify unusual performance patterns, and predict where fill weights could be reduced while maintaining production requirements.
The analysis also helped differentiate normal operating variation from potential mechanical issues, providing a more targeted basis for evaluating improvements.
What the Data Revealed: Million-Dollar Savings Potential
The financial findings demonstrated how small variations can become significant in a high-volume manufacturing operation.
The analysis identified between $1 million and $1.1 million in annual product loss. It also showed that reducing fill weights by approximately 4 to 8 grams per fill could yield estimated savings of $300,000 to $800,000 per line annually.
While a few grams on an individual fill may seem insignificant, when multiplied across millions of production cycles, the impact becomes substantial.
The project also uncovered a filling head exhibiting mechanical drift. Correcting the issue provided a reported benefit of approximately $40,000 to $50,000 while helping to reduce the risk of underfilling. This finding demonstrated that the value of detailed process analysis is not limited to long-term optimization. It can also help identify specific maintenance issues that might otherwise go unnoticed.
Rather than making broad adjustments based on average line performance, the manufacturer could focus on individual equipment behavior and evaluate improvements based on their potential operational and financial impact.
Turning Insight into Action: Real-Time Optimization
Identifying an opportunity is only the first step. The next challenge is determining how to translate these findings into sustainable improvements. For this manufacturer, the analysis established a foundation for a potential next phase involving real-time, closed-loop optimization.
The proposed approach would use predictive models in an edge-based architecture to evaluate changing process conditions and support automated filling adjustments. This could help reduce unnecessary loss while maintaining required fill weights and identifying changes in equipment behavior over time.
Moving to closed-loop control would require additional engineering, validation, and integration with existing automation systems. The estimated savings would also need to be validated through implementation and ongoing performance monitoring.
Not every manufacturing challenge requires this level of automation. Depending on the findings, the most valuable next step could involve maintenance, process adjustments, improved reporting, or a more comprehensive technology investment.
The key is having sufficient information to make that decision based on measurable opportunities rather than assumptions.
The Broader Opportunity: Creating Value with Data
While this project focused on product loss, the same approach can be applied to other manufacturing challenges, including process variability, quality losses, scrap, and production inefficiencies.
Many facilities already have valuable operational data available. The challenge is understanding what this information reveals and how it can be used to guide improvements.
For the filling line manufacturer, a closer look at existing data uncovered a mechanical issue, quantified significant product losses, and built a business case for further optimization.
Other applications will involve different challenges and solutions, but the starting point is the same: understanding the problem, using available data to investigate it, and identifying where improvements can deliver measurable value.
