🔌 Compact Industrial Connectivity Solution: Han 3A Domino Adapter!
Elif Ă–zaksu
  • Altanlar
    Connection Technology That Achieves Big Things in Small Spaces​
    Machine manufacturers and automation engineers are under increasing pressure to fit more functions into smaller interfaces. Different connections such as power, signal, Ethernet data, and compressed air need to pass through a single point. HARTING has developed the Han 3A Domino Adapter to address this need. This adapter integrates miniature Han-Modular Domino modules into compact Han 3A housings, offering a space-saving solution for industrial automation, machine building, and process equipment.
    Why Are Modular Industrial Connectors Shrinking?​
    Modular rectangular connectors allow different contact types to be combined in a single housing. HARTING's Han-Modular system, introduced in 1993, pioneered this concept. The Domino generation, however, divided each module into two independent halves (Domino Cubes), making them half the size of classic Han-Modular modules. This doubled the number of possible combinations of modules with different connection types, power ratings, and transmission media. Since 2022, Domino modules have been integrated into standard B-sized housings, and HARTING is increasingly adopting smaller housings for installation locations.
    How Does the Han 3A Domino Adapter Work?​
    The Han 3A Domino Adapter (part numbers 97000006077 and 97000006078) acts as a carrier frame that holds the Domino Cubes within the Han 3A housing. It fits commonly used housings such as the Han M, Han HPR, and Han Inox variants, as well as the Han-Yellock 10 and HARTING ICC 20 series. Compatible Domino Cubes cover power, signal, data, and compressed air. HARTING describes the adapter as the smallest modular frame available in the industrial sector.
    Assembly is largely tool-free, and the RearFit option supports faster installation, saving time and costs. The connector can be used as a panel-mounted interface or a flying connection between two cables.
    Data and Pneumatic Connections in Tight Spaces​
    High-speed data transmission is one of the primary applications of this adapter. The adapter supports Cat 5 and Cat 6A data classes via RJ45, M12, megabit, and gigabit modules. Additionally, with USB-C support, Ethernet and service interfaces can be provided in a housing that would normally be occupied by a single insert. Pneumatic modules allow compressed air to pass through the same connector as electrical signals, reducing the number of separate connections in machine modules. For temperature measurement, Domino Cubes with J and K type thermocouple contacts offer a space-saving solution for analog measurement signals.
    Housing Options and Environmental Protection​
    The Han 3A housing range extends from plastic to stainless steel, with protection classes from IP54 to IP69K. IP69K means protection against high-pressure, high-temperature water jets used in washdown cleaning. This makes the stainless steel variants suitable for hygienic environments such as food processing and packaging machines. Plastic housings are used in less demanding machine and control panel environments.
    Machine Building and Automation Applications​
    Typical applications include modular machines with interchangeable units, conveying and robotic equipment, pneumatic actuators requiring both air supply and sensor feedback, and service interfaces requiring Ethernet or USB-C access. Combining these functions in a single compact connector reduces panel cutouts, simplifies wiring, and supports faster changeover and maintenance.
