🤖 Contactless, Optical, and Single-Cable Connectivity Solutions for Automation and Robotics! 🚀
  • HSCQ
    Future Industrial Connectivity Technologies from Rosenberger​
    At the SPS 2026 exhibition in Nuremberg, Rosenberger introduced RF, high-voltage, and fiber optic interconnect solutions aimed at data and power transmission for autonomous systems and machine vision. The company focused on industrial automation, robotics, and smart engineering applications, exhibiting in Hall 9, Booth 330 from November 24-26, 2026.
    Connectivity Requirements in Autonomous and Networked Systems​
    The increasing use of autonomous systems, connected machines, and industrial machine vision elevates the requirements for connectivity solutions. These solutions must reliably transmit data and power, integrate into machines and systems in a space-saving manner, and operate flawlessly in harsh environmental conditions. Rosenberger's exhibited portfolio covers a wide range, from RF and high-voltage connections to compact Ethernet interfaces and optical transmission solutions.
    Single-Cable Machine Vision and Robotic Connections​
    For robotics and automation, Rosenberger showcased connectivity solutions for autonomous mobile robots and industrial robotics. These include HySpeedVision (HYV), a single-cable solution for image data and power transmission in machine vision applications.
    Contactless Data Transmission and Single Pair Ethernet​
    RoProxCon enables contactless transmission of data and power. Single Pair Ethernet provides compact connections for networked industrial systems.
    Expanded Beam Fiber Optics and Smart Engineering​
    EBM (Expanded Beam Multifiber) offers robust optical connections for harsh environmental conditions. Rosenberger complements this with customized engineering solutions for autonomous tracking applications.
    Rosenberger's Vision for the Future​
    Marc Käumle, Vice President at Rosenberger, stated, "The future of industrial connectivity will not only be defined by higher data rates or more compact interfaces, but by the intelligent interaction of different technologies. The key lies in the seamless integration of data and power transmission, reliability, and performance. At Rosenberger, our goal is to actively shape this development and lay the foundation for the next generation of smart, connected industrial systems through innovative technologies."
    Technical Details and Competitive Analysis​
    • HySpeedVision (HYV): In industrial machine vision, it provides 12 Gbps and 36 W of power in a compact M12 footprint using automotive SerDes protocols (such as GMSL3). It differentiates itself from competitors like Power over CoaXPress (PoCXP) and 10GigE PoE.
    • RoProxCon: In contactless connectivity, it eliminates the mechanical wear of traditional slip rings, offering up to 3.125 Gbps data and a 7 ns latency. While limited to 30 W power and a 20 mm air gap, it competes with 60 GHz couplers like TE Connectivity's ARISO.
    • EBM (Expanded Beam Multifiber): In harsh environment fiber optics, it meets MIL-DTL-38999 durability standards, providing insertion loss typically below 0.35 dB (single-mode) over 5,000 mating cycles. It competes with TE Connectivity's PRO BEAM and Amphenol expanded beam systems.
