🌐 Industrial Systems at Risk
As cyberattacks become increasingly common, attackers are gaining access to systems through internet-exposed Programmable Logic Controllers (PLCs), which are frequently used in industrial sectors. This makes organizations, regardless of their size, vulnerable to attacks.
⚠️ Critical Warning from FBI and EPA
In July, the FBI and the Environmental Protection Agency (EPA) warned critical infrastructure asset owners and operators that malicious cyber actors were conducting cyberattacks targeting Operational Technology (OT) devices. These attacks included Rockwell Automation/Allen-Bradley PLCs and Siemens controllers targeted with AI-generated code.
🔒 PLC Vulnerability: A Design Flaw?
Patrick Lamplmair, CTO of industrial IoT data infrastructure provider Tributech, stated, "PLCs were built for closed plant networks where anyone who could reach the device was trusted. Remote connectivity was added later, but the trust model remained the same." Lamplmair explained that remote access via cellular modems saves time and money, but it is also why many controllers are accessible from the internet and thus vulnerable to attacks.
Lamplmair added, "A PLC cannot distinguish an operator from an attacker. Once someone reaches it, it accepts a new password, a new IP address, or new logic without question. This design assumption has turned a simple login into locked-out operators and boiling water notifications."
💧 Water Facilities Targeted
Since July, water and wastewater utilities in at least seven states have reported incidents to the FBI. Attackers targeted internet-exposed PLCs used to monitor and control industrial equipment in water and wastewater facilities, changing their IP addresses and passwords. This led to a loss of monitoring and control.
While the FBI noted that this behavior was observed only in Rockwell PLCs, it emphasized that similar considerations should be taken for other brands of PLCs.
👨💻 Resource Scarcity a Major Problem
In many small-scale facilities, the same individuals who operate the water treatment plant may also handle network administration, SCADA management, compliance reporting, and cybersecurity tasks. This, combined with a lack of resources and a shortage of OT cybersecurity specialists, exacerbates the problem.
"Size no longer keeps a facility off the target list," said Lamplmair.
🚀 Start with the Basics: First Steps for Cybersecurity
As attacks continue to affect manufacturers and other organizations in the U.S., companies are preparing for the upcoming requirements of the European Union's Cyber Resilience Act (CRA), which came into force last year and brings a significant change in how manufacturers in the EU manage cybersecurity for connected products.
Regarding how organizations can prepare for attacks in the current threat landscape, Lamplmair said that starting with access is crucial.
"Start with the basics: find out which controllers are externally accessible, take them off the public internet, and set a strong password for each," Lamplmair said, adding that remote access via VPN should be the only exception.
Lamplmair also stated, "With zero trust, users and applications no longer gain network access to the control system. They get permission to read or write specific values and can do nothing else. Existing facilities can add this as software at the IT/OT boundary without changing their controllers."
While segmentation and patching are still important, they only provide a defense around the controller. "The next step is zero trust at the command level: every write to a control system is tied to a verified identity and checked against safe operating limits before it reaches the device.
