🚀 Automatic Commissioning in Hygienic Process Valves: Universal Control Heads from Bürkert! 🚀
💡 Next-Generation Control Solutions from Bürkert​
Bürkert Fluid Control Systems has launched Tip 8682 and Tip 8683, innovative control heads for the food, pharmaceutical, and biotechnology sectors. These products provide decentralized automation for pneumatically operated hygienic and aseptic process valves. Combining control, position monitoring, feedback, and diagnostic features, these devices integrate with third-party single/double-seat, butterfly, and ball valves, supporting standardization in facilities.
🛠️ Universal Compatibility and Easy Installation​
These control heads are compatible with all commercially available pneumatic butterfly, ball, single-seat, and double-seat valves. This reduces the complexity of selecting, training, stocking, and maintaining different types of control heads. Ideal for valve matrices and distributed systems, these products offer quick and precise installation thanks to valve-specific adapters. The 24 VDC power supply and communication connections can be established with standard industrial cables or AS-Interface/IO-Link options.
⚙️ Pilot Valve Configurations and Position Sensing​
  • Type 8682: Designed for single-seat and butterfly valves. Offers feedback for monitoring and reporting valve position, or pilot valve options for 3/2-way or 5/2-way pneumatic operation.
  • Type 8683: Supports double-seat, single-seat, and butterfly valves. Can be equipped with up to three 3/2-way pilot valves.
Both control heads are capable of sensing 86 mm linear movement with 0.03 mm resolution or 359° rotational movement with 0.2° resolution.
⏱️ Automatic Commissioning and "Teach-in" Modes​
The control heads feature automatic commissioning, enabling almost instant startup. The "Teach-in-Operation" mode, activated out of the box, detects end positions during operation. This ensures seamless valve replacement and immediate operation even before end positions are learned. Additionally, "Teach-In manual" and "Teach-in Auto" modes are available for setting valve end positions via the device keypad or Bürkert's Communicator software.
🔍 Advanced Diagnostics and Cleaning Functions​
Along with an LED indicating device and environmental status according to NAMUR NE 107 standard, an additional LED around the control head shows the current valve position. The integrated diagnostic system evaluates switching times, positions, and deviations to detect faults, wear, and irregularities early, thereby reducing unplanned downtime.
For hygienic applications, cleaning modes based on time and stroke parameters can be adjusted according to process, valve, and media requirements. Both control heads include pulsed seat lift cleaning to enhance cleaning efficiency and reduce cleaning media consumption. Type 8683 also offers CIP.SAVE control, which creates a turbulent flow profile with cyclical seat movement, reducing cleaning media usage and providing precise timing with feedback.
🛡️ IP69K Protection and Durability​
New housing designs, along with EPDM external seals and EPDM, FKM, or NBR internal seals, provide IP69K protection, ensuring reliable operation in high-pressure washdown environments, both indoors and outdoors. The control heads are also designed for reliable operation under vibration and shock.
🌟 Market Position​
Compared to Alfa Laval's ThinkTop V70, Bürkert's Type 8682 and 8683 models offer the flexibility to adapt to commercially available valves from other manufacturers using valve-specific adapters. This is a significant advantage for businesses looking to upgrade automation while retaining existing infrastructure in their facilities.
