Elif Özaksu
🛠️ Time Savings in Field Assembly
Field assembly of heavy-duty rectangular connectors can often be challenging due to confined spaces and tight timelines. To overcome these challenges, HARTING has added 14 new one-piece connectors to its Han Push-In monoblock series. These innovative additions offer tool-free field assembly, significantly reducing installation times.
🔧 How Push-In Technology Works
Push-In technology is an advanced version of cage clamp connection. Conductors with wire end ferrules are inserted directly into the contact chamber. Once the ferrule reaches the bottom of the chamber, an internal clamping spring secures the wire and provides tensile strength. For bare wires without ferrules, the spring is held open by pressing the orange actuator with a screwdriver, and the conductor is then inserted. Although HARTING recommends the use of ferrules, multi-stranded and solid conductors can also be connected.
🚀 New Han Series Push-In Inserts
The new Han Push-In monoblock inserts cover the Han E and Han EE series in four standard sizes (Han 6, 10, 16, and 24), and the Han D and Han A series in two standard sizes (Han 10 and 16). According to HARTING, direct insertion of the conductor reduces assembly time by up to 30% compared to alternative termination technologies. Since these inserts are compatible with similar products using other termination methods, existing connector housings and mating sides can be retained.
🟢 Green PE Actuator for Safe Wiring
For the first time, Push-In monoblocks feature a green actuator for the protective earth (PE) contact. This clearly distinguishes it from the orange actuators of the power and signal contacts, reducing the risk of wiring errors in the protective conductor during field assembly.
🏭 Applications in Energy and Machine Manufacturing
These inserts are designed for environments where there is limited space for installation, assembly, and maintenance. Typical applications include energy applications, installation of machine modules, and connection of production lines. Tool-free operation also simplifies maintenance work, as conductors can be released and reconnected without special equipment.
💡 Additional Information
Spring-based termination methods for industrial connectors have offered advantages over screw terminals because the contact force is applied by the spring rather than the installer. This eliminates torque-related variations and reduces sensitivity to vibration. Clamping units for copper conductors are specified under IEC 60999-1, while heavy-duty connectors are specified under IEC 61984. Push-in variants differ from traditional cage clamp terminals by allowing ferruled or solid conductors to be inserted without first opening the spring; this is the main source of the time savings stated by manufacturers.
