🚀 Next-Gen Precision for Reflective Surfaces from Baumer!
Baumer is revolutionizing industrial automation by adding new variants with green laser optics to its compact OM60 laser distance sensor family. These new sensors offer micrometer-level precision at measurement distances up to 1 meter on shiny metallic and plastic surfaces.
🔍 Why Green Laser?
In industrial production, reflective or glossy targets such as polished metals, coated films, and smooth plastics are frequently encountered. Traditional optical triangulation sensors with red lasers can experience measurement noise and linearity errors on such surfaces due to beam reflection, saturation, and scattered light. Baumer's OM60 sensors with green lasers overcome these challenges thanks to their shorter wavelength, significantly increasing measurement reliability on reflective materials.
🎯 Dual Lens Optics and Micrometer Precision
The new green laser models provide micrometer-level precision across the entire measurement range at distances up to 1 meter. The optical architecture includes a dual-lens system specifically designed for the green laser wavelength. This optimizes beam focus and light reception on challenging target surfaces. Across the OM60 product family, the sensors offer a linearity deviation of ±3 µm and repeatability of 0.12 µm. This precise feedback supports critical control tasks such as accurate Z-axis positioning of processing heads in laser marking systems and continuous roll diameter monitoring in shiny web materials.
⚙️ Mechanical Stability and Industrial Integration
The new green laser variants retain the mechanical and electronic architecture of the existing OM60 platform. The sensor housing features a mechanical structure designed to ensure high temperature stability and consistent measurement output even when exposed to ambient mechanical vibrations in active machinery. For streamlined machine integration, the sensors feature an onboard display as well as digital communication interfaces supporting IO-Link and Modbus RTU. These interfaces allow automation engineers to parameterize sensor settings, monitor diagnostic telemetry, and integrate distance feedback directly into programmable logic controllers.
💡 Technical Details and Market Positioning
Green laser diodes (typically 515 to 532 nanometers) exhibit higher diffuse scattering and lower specular glare on polished metals, copper, silicon wafers, and shiny polymers compared to standard red laser diodes (approximately 650 to 660 nanometers). This specifically prevents the expansion of the laser spot and deep beam penetration, which distorts CMOS receiver center detection in translucent plastics. The OM60 series supports measurement frequencies up to 3.3 kHz and temperature drift rates lower than 0.1 µm per Kelvin. With these new sensors, Baumer bridges the gap between standard photoelectric distance sensors and metrology probes with external controllers.
