🚀 Direct Drive Frameless Motors in Gimbal Design: Why Are They So Important? 🚀
    Introduction​
    Gimbals that stabilize and orient cameras and sensors must combine critical requirements such as fast response, precise positioning, and sufficient space for cables, slip rings, and even cooling lines. ALVA Industries offers solutions to these challenges with its SlimTorq™ slotless frameless motors. These motors provide backlash-free direct drive, zero torque ripple, and a large inner bore for cable routing.
    Gimbal Drive: Geared or Direct Drive?​
    Gimbal motion systems typically employ one of two main architectures: systems where the motor is coupled with a gearbox, or direct-drive motors. While mass is often the determining factor in aerial gimbals, dynamic performance and precision take precedence in non-aerial designs where weight is less critical.
    According to ALVA Industries, the direct-drive configuration offers higher peak torque, which translates to greater responsiveness and shorter settling times after commanded motion. Since there is no gearbox in the drive system, there is no backlash to compensate for in the control loop, leading to more precise positioning and smoother tracking.
    Large Inner Bore for Cable Routing and Slip Rings​
    A direct-drive frameless motor typically offers a larger central opening compared to similar geared or slotted solutions. In a gimbal, this inner bore can be used to route cables directly along the axis instead of around the motor. The choice of slip ring is less affected by space constraints within the motor, and where sensors require active cooling, cooling lines can be routed through the same bore. The result is a more compact mechanical arrangement with fewer external cable runs.
    How Slotless Frameless Motors Prevent Torque Ripple?​
    The SlimTorq™ series consists of slotless, thin-section frameless motors, with non-aerial gimbals being among their most common applications. The removal of stator iron teeth eliminates torque ripple, which is the periodic variation in torque caused by the alignment of magnets with stator slots. This is a crucial factor for smooth low-speed motion and accurate orientation.
    Traditionally, slotless motors traded this smoothness for lower torque density. ALVA Industries counters this with its FiberPrinting™ manufacturing process. This process combines a Halbach array rotor, which concentrates magnetic flux, with high copper fill factor and non-skewed stator windings. The company states that the resulting motor constant and torque density are comparable to slotted designs. The thin stator and rotor also increase the available inner diameter for the inner bore.
    These motors are three-phase BLDC types and can be driven by most off-the-shelf controllers in trapezoidal, sinusoidal, or field-oriented control modes, with or without sensor feedback. Due to their low inductance, the driver's switching frequency must be chosen accordingly. The series is available in a Lite version optimized for low mass and a Max version optimized for torque and motor constant.
    Custom Motors for Specific Gimbal Envelopes​
    In cases where no standard size fits an application, ALVA Industries states that the flexibility of FiberPrinting™ allows them to develop custom motors tailored to the required spatial envelope and performance.
    Additional Information​
    Precision gimbals and pointing systems typically use either geared drives (often with strain wave or planetary gearboxes) or direct-drive frameless torque motors. Gear stages increase output torque but introduce effects such as backlash, torsional compliance, and friction, which limit stiffness and bandwidth in closed-loop pointing. Direct drive eliminates these transmission effects but requires a motor that itself provides all the torque for the axis.
    Frameless torque motors are divided into slotted, iron-core designs that offer high torque density but typically exhibit torque ripple, which is reduced by skewing at the expense of the torque constant, and slotless designs that eliminate torque ripple but have a larger magnetic air gap. Halbach magnet arrays and higher winding fill factors are established engineering methods to recover torque density in slotless machines.
