🌟 Maxon Innovations Simplify Industrial Automation 🌟
Maxon is elevating industrial automation with functionally safe robotic joints, CANopen positioning controllers, and an expanded frameless motor series, all showcased at the SPS exhibition. These innovations offer integrated drive systems, functional safety architectures, and predictive maintenance software for autonomous mobile robots (AMRs), humanoid robots, and automated logistics systems.
⚙️ Core Technology and System Architecture ⚙️
At the heart of Maxon's innovations are compact electromechanical drive components designed with embedded functional safety and open fieldbus interfaces. The High-Efficiency Joints platform integrates semi-direct drive motors with functional safety capabilities such as Safe Limited Torque to manage force limits during dynamic balancing and physical manipulation. The ESCON2 servo controller series transforms into a CANopen positioning controller, supporting Profile Position, Cyclic Synchronous Position, and Homing modes. Furthermore, mechanical actuation options are expanded with the EC frameless Dynamic Torque motor series, featuring high copper fill factors, integrated Hall sensors, and large hollow shafts for internal cable routing, along with zero-backlash strain wave gearboxes.
🛠️ Ease of Application and Integration 🛠️
These drive components can be utilized as modular electromechanical sub-assemblies or as complete, custom-engineered drive and actuation units. Existing ESCON2 hardware installations can be upgraded to full CANopen positioning capability with a free firmware update to be released in December 2026. The new functionally safe High-Efficiency Joints maintain mechanical and electrical backward compatibility with legacy joint architectures, allowing robotic developers to integrate safety functions into existing chassis designs. System-level integration is demonstrated on an interactive AMR model connecting maxon Wheel Drives, IDX industrial drives, custom-engineered assemblies, and the maxon MIND condition monitoring platform.
🏭 Industrial Applications 🏭
These technologies serve numerous sectors, including robotic manufacturers, automated guided vehicle developers, laboratory automation integrators, and optical equipment manufacturers. When designing multi-axis manipulators, legged robots, and autonomous logistics vehicles, high torque density is required within constrained joint envelopes while preventing unwanted mechanical force deviations near human operators. The combination of hollow-shaft frameless motors, zero-backlash strain wave gearboxes, and firmware-upgradable positioning controllers eliminates external cabling bottlenecks and simplifies multi-axis kinematic synchronization.
📈 Operational Impact and Performance Metrics 📈
The direct integration of Safe Limited Torque into semi-direct drive joints eliminates the burden of external safety relays and maintains compact actuator footprints during collaborative manipulation tasks. The use of firmware-based CANopen positioning in existing ESCON2 controllers extends hardware lifecycle benefits and avoids re-engineering costs. Continuous collection of drive telemetry via the maxon MIND predictive maintenance platform enables early detection of mechanical wear anomalies, stabilizing fleet availability and preventing unplanned downtime in automated logistics and manufacturing operations.
