🔒 Cyber Security Integrated Modular PLC: A New Era in Industrial Automation with OMRON CJ3M! 🚀
Ahmet Ă–.
    Next-Generation PLC from OMRON: CJ3M​
    OMRON has introduced the CJ3M, a new programmable logic controller (PLC) that offers built-in security, high-speed command execution, and backward compatibility for industrial automation systems. This modular PLC addresses cybersecurity and performance challenges encountered when modernizing legacy systems.
    Challenges of Modernizing Legacy Systems and CJ3M's Solution​
    Modernizing existing industrial control systems forces engineers to balance strict cybersecurity compliance and faster processing speeds against the high cost and downtime of re-engineering entire control panels. The CJ3M modular PLC, the latest generation of OMRON's CJ series, is designed to resolve this operational bottleneck. Upgrading legacy PLCs often requires extensive panel modifications, rewiring of I/O modules, and complete software re-engineering. At the same time, increased network connectivity on the factory floor exposes operational technology infrastructure to unauthorized access and data manipulation. The CJ3M offers modular control architectures that meet new regulatory frameworks while preserving existing hardware and software investments.
    System Architecture and Processing Performance​
    Designed for large-scale system applications, new machine configurations, and the expansion and modernization of existing installations, the CJ3M combines higher performance with long-term global availability. The modular controller manages up to 5,120 I/O points across a maximum of seven expansion racks. It provides up to 100,000 steps of program memory for complex control logic and 40,000 steps dedicated to function blocks, executing basic commands in 0.04 microseconds. Communication bandwidth reaches 12,000 packets per second, and integrated Ethernet capabilities support EtherNet/IP, Modbus/TCP, and socket communications. To allow for precise scaling according to machine size, the product range includes ten CPU models with 5,000 to 100,000 program steps, with or without built-in EtherNet/IP. When paired with a pulse I/O block, the controller can also perform simple positioning for up to four axes.
    Built-in Cybersecurity and Regulatory Compliance​
    Rather than relying solely on external network firewalls, the CJ3M integrates cybersecurity functions as standard. These include encrypted communications, user authentication with role-based account management, IP packet filtering, and port opening/closing control to protect systems against unauthorized access, data tampering, and information leaks. From a regulatory perspective, the controller complies with mandatory Chinese GB standards, and compliance with the European Union Cyber Resilience Act (CRA) is planned.
    Engineering Workflow and Maintenance Optimization​
    Programming is performed with CX-Programmer, the established tool within OMRON's CX-One software suite, supporting Ladder Diagram, Structured Text, and Sequential Function Chart. Engineers can register monitoring variables directly from the Ladder program or the Watch window, CPU tag sets for EtherNet/IP data links are automatically generated, and a larger monitoring memory speeds up debugging. Battery-free operation eliminates routine battery management and replacement; a battery is only necessary if the clock function is used and the equipment may experience prolonged power outages. Global standard USB Type-C and SD card interfaces simplify accessory procurement in any region.
    Four-Step Migration for Existing CJ2M Installations​
    For facilities using CJ2M controllers, the CJ3M provides a direct upgrade path without requiring a major redesign. Since it is compatible with existing CJ2M programs, memory maps, and I/O units, engineers can upgrade the system by simply replacing the CPU unit. The migration follows four steps: reading the project, converting the data, replacing the CPU unit, and finally transferring and verifying. A replacement path is also available for the CS series.
    Additional Information​
    In industrial automation, maintaining backward compatibility between controller generations is a key strategy to minimize downtime and capital expenditure in existing facilities. Modular PLCs like the OMRON CJ series compete with platforms such as Siemens SIMATIC S7-1500 and Rockwell Automation CompactLogix 5380. While some new controller generations require extensive I/O and software changes, preserving program, memory map, and I/O compatibility allows OEMs and plant operators to extend asset lifecycles while meeting cybersecurity requirements like IEC 62443 and the EU Cyber Resilience Act.
