Elif Ă–zaksu
🤔 Understanding the Cooling Cost of AI Servers
When a factory adds AI servers for a vision inspection system next to its production line, it can easily see the cost of the servers and their electricity consumption. However, determining the cooling cost is more difficult because it is often met by existing plant equipment.
When cooling demand is mixed into factory overhead, the project team overlooks a portion of the operating costs. This makes it difficult to budget for future expansions and prevents the verification of cooling savings claims.
Before approving more servers, ask the IT and facilities management teams to explain how the initial installation is cooled and what electricity consumption can be attributed to it.
📏 Defining Measurement Boundaries
Liquid-cooled servers can be connected to a shared chilled water plant via a coolant distribution unit. Some server heat may still escape into the room air. Therefore, the cooling boundary should include the relevant fluid path and any additional room cooling demand, rather than assuming the water connection covers everything.
Also, map out the electrical supplies. Does the server meter already include the pumps or fans of a cooling unit? Are these loads on a separate panel? Counting the same equipment twice can make a seemingly careful cost estimate incorrect.
Ensure the plant engineer and IT lead agree on the map, then identify what is directly measured, shared, and needs to be estimated. The finance team should be able to follow these distinctions without having to interpret a piping diagram.
⚡ Separating Heat Rejection and Electricity Consumption
In a liquid connection, the flow and the difference between supply and return temperatures, along with the appropriate properties of the actual fluid, can be used to estimate heat transfer. When this rate is integrated over time, it gives the thermal energy rejected. Especially when temperature differences are small, meter selection, installation, and measurement uncertainty are important.
This thermal energy is not the electricity consumed by the cooling plant. Rejecting a certain amount of heat may require different electrical input as external conditions, plant loading, and control sequences change. While a pump serving the AI loop may have a directly measurable electricity cost, the servers' share of the central chiller remains an allocation.
Suppose the AI branch accounts for 20% of the heat rejection measured over a specific interval. Allocating 20% of the shared plant's electricity to it can be a useful accounting rule. However, this does not prove that shutting down these servers will reduce plant electricity by 20%. The shared equipment may continue to operate or change its operating point.
Label the result accordingly. A useful estimate is more reliable when its boundaries are visible.
📊 Comparing Equivalent Work
A lower electricity bill after an AI deployment does not demonstrate cooling improvement. Perhaps the weather changed, a production line ran fewer hours, or the inspection workload decreased. The U.S. Department of Energy's guidance on energy information systems emphasizes the role of relevant operating conditions when evaluating performance.
For a factory inspection application, compare intervals with similar production and computational demand. Track model or software changes that could alter processing requirements. Consider inspection scope, quality, and response time requirements: doing less useful work is not an efficiency gain.
A facility can track thousands of cooling electricity per completed inspection, provided it defines what a completed inspection means and keeps the allocation method consistent. Another application will require a different denominator. The metric should help the operations team explain a change, not just produce a smaller number.
Use synchronized records and retain enough detail to investigate events behind weekly totals. A commissioning baseline captured before routine changes accumulate offers the team a much stronger starting point than a reconstructed estimate months later.
🤝 Bringing IT and Facilities Management Together
IT can report server workload without seeing the chiller. Facilities management can report chiller operation without knowing that a model update changed the computational load. Finance receives the cost of both.
Assign one person to bring these perspectives together. A brief, recurring review should ask what changed in useful output, what changed in cooling electricity, and what assumptions still need to be checked. New meters should answer a specific, unresolved question rather than expanding a dashboard no one owns.
The next investment decision can use three clearly separated figures: directly measured cooling electricity, allocated shared electricity, and any remaining estimate. Energy cost calculations also require the applicable tariff; peak demand charges may require separate consideration.
At the next budget review, the team should be able to show where the cooling cost figure came from, what assumptions it includes, and what expansion might change. A documented estimate can support this discussion. An unexplained share of the factory's overhead cannot.
