🤖 Custom Solutions for Industrial Robots: Smart Cable Packages from LÜTZE!
    The Secret to Seamless Motion in Industrial Robots: LĂśTZE's Next-Generation Cable Packages​
    In industrial automation lines, the multi-axis movements of robots expose power, data, and media lines to intense torsion, bending, and wear. This can lead to unplanned downtime and complexity in system engineering. Automation specialist LĂśTZE has introduced its new "Robotic Solutions" product area to address these challenges.
    Why Are Special Cable Packages Important?​
    In automated production cells, routing energy, pneumatic, fluid, and welding lines along robot arms creates significant mechanical challenges. Rapid acceleration, tight bending radii, and continuous torsional stress can cause premature fatigue and wear of cables. Furthermore, working with separate suppliers for cables, protective conduits, connectors, and mounting hardware creates engineering bottlenecks and fragmented responsibility for system integrators and plant operators.
    LĂśTZE's End-to-End Approach​
    Germany-based LĂśTZE adopts a consistent system approach in this field. It offers all services from a single source, from technical design to production, quality assurance, service, repair, and replacement. Each solution is custom-designed for the specific robot type, motion profile, media, and environmental conditions. The product range extends from structured empty conduit packages to motion-optimized robot cable packages and fully pre-assembled and tested systems. In these systems, energy, data, and signal cables, bus cables, pneumatics, fluids, welding current, and other process media can be combined into a single system. LĂśTZE develops solutions for all common robot types and load classes, from six-axis articulated robots to palletizers and collaborative robots.
    Controlled Routing and Protection in Harsh Environments​
    Cable packages are motion-optimized for long service life and operational reliability. Retraction and holding systems, mounting elements, and suitable protective and corrugated conduit systems ensure clean and controlled hose routing throughout the entire range of motion. Harsh environments such as welding spatter, grinding dust, or coolants are considered during the design phase. Since LĂśTZE also undertakes technical design and system integration, cables, wires, protective systems, connectors, and mounting are matched to create a functionally reliable system. This results in clear responsibilities, fewer interfaces, and repeatable production quality.
    Scalable Production and Amphenol Expertise​
    Production is scalable from single units to large series. Prototyping, initial product inspection, and documented bills of materials and drawings provide a solid foundation for series approvals, replacement, and long-term spare part availability. This offering targets system integrators, plant manufacturers, OEMs, and operators of automated systems. The combination of LĂśTZE's local development expertise with the global resources of the Amphenol Group allows for the integration of cables, wires, and connectors from a broad technology and product portfolio. Thus, users receive a complete system from a single responsible partner, instead of coordinating several separate suppliers.
    Fast Support in Case of Service​
    The portfolio is complemented by maintenance, repair, overhaul, and damage analysis services. Damaged cable packages are analyzed, repaired, or, if necessary, remanufactured, regardless of the brand (including cable packages from other manufacturers and existing installations). In the future, LĂśTZE also plans to offer service solutions aimed at reducing downtime, thereby making a significant contribution to system availability in production-critical robotic applications.
