🚀 Decentralized Automation Solutions from Murrelektronik at SPS 2026!
    💡 Decentralized Automation: A New Era in Mechanical Engineering​
    At SPS 2026, Murrelektronik showcased new automation approaches under the motto "Decentralized Automation," which reduce wiring, shorten installation times, and increase flexibility in machine and plant engineering. The company is breathing new life into industrial automation by offering consistent solutions from planning to operation with digital tools, together with its customers and partners.
    ⚙️ Vario-X: Bringing Automation to the Field​
    Murrelektronik's Vario-X platform brings automation functions directly to the field. This system, which combines hardware, software, and installation technology in a single modular structure, enables quick plug-and-play installation thanks to pre-assembled cables and standard interfaces. This allows automation functions to be easily adapted to different requirements and machine concepts to be expanded effortlessly.
    💻 Digital Twin: Virtual Planning, Real Construction​
    Digital twin technology enables the planning of decentralized machine concepts in the virtual world. With precise 3D models based on circuit diagrams, components, wiring, and cable lengths can be planned and checked before physical installation. This allows changes to be tested virtually and assembly effort to be assessed at an early stage. Additionally, digital model simulations support virtual commissioning and training.
    🛠️ uKonn-X: Step-by-Step Guided Installation​
    With uKonn-X, digital planning data is transformed into concrete installation guidance on the machine. Components and connections are uniquely identified by scanning and assigned to the relevant installation step. The application directly shows the next work steps, supporting structured and traceable assembly, while digitally documenting progress. This automatically creates documentation of the installed state, which can be used for later modifications, expansions, and service.
    🔌 Power, Signal, and Data Connection​
    Decentralized automation requires suitable connections for power, signal, and data. Murrelektronik offers a wide portfolio of connectors and pre-assembled cables, such as the MQ15 power connector, which transmits high currents in a small space and ensures quick assembly. The plug-and-play principle also reduces wiring effort.
    📡 IO-Link Innovations: Down to the Sensor-Actuator Level​
    IO-Link enables the standardized transmission of data, diagnostics, and parameterization down to the sensor-actuator level. Murrelektronik expands options for decentralized installations with pure.IO and the new IO-Link Multiplier. These solutions enable flexible distribution and connection of IO-Link devices, providing more room for planning and expanding machines.
    🔄 MVK Fusion CIP Safety: Three Functions in One Module​
    Modular machines often use separate modules for standard I/O, safety I/O, and IO-Link. MVK Fusion combines these three functions in a single fieldbus module, reducing wiring and engineering effort and enabling a more compact design. With MVK Fusion CIP Safety, this 3-in-1 concept is now also available for EtherNet/IP.
    📸 Machine Vision and Industrial Networking​
    With the increasing use of cameras in machines and systems, a suitable infrastructure is becoming increasingly important. Murrelektronik offers modular, manufacturer-independent installation solutions that combine power supply, communication, and additional signals directly in the machine environment. Furthermore, Xelity managed switches bring powerful network communication directly to the field, and with Xelity Wave Pro, industrial wireless communication transmits control, fieldbus, and safety signals wirelessly in real time.
    📈 Industry Trends and Murrelektronik's Contribution​
    Moving I/O and control functions from the control cabinet to the field is a growing trend in modular machine construction. This shortens cable lengths, reduces cabinet size, and allows machine modules to be pre-assembled and tested independently. Standard communication technologies like IO-Link play a central role by providing access to device parameters and diagnostics down to individual sensors. Combining standard I/O, safety I/O, and IO-Link in a single IP67 module reflects a broader industry movement towards consolidated field devices that support safety protocols like CIP Safety and PROFIsafe. Coupled with digital twins and guided installation tools, these approaches aim to reduce wiring errors and commissioning time, which continue to be significant cost factors in machine and plant engineering.
