🛠️ Next-Generation Cable Glands Accelerate Assembly Processes
In modern production environments, engineers often face the challenge of securely routing cables into double-walled or high-hygiene enclosures. As a solution to situations where traditional rear-mounted locknuts are impractical or pose a risk of contamination, automation specialist LÜTZE has expanded its product range with new snap-in plastic and metal cable glands.
These new snap-in glands can reduce assembly time by up to 70% thanks to the integrated locknut being tightened from the front of the panel. Designed for wall thicknesses from 0.5 to 4.0 mm, these components offer wide clamping ranges, high tensile strength, and reliable strain relief. With IP66 and IP68 (5 bar, 30 minutes) protection classes, they provide superior protection against dust and water.
🧼 Hygienic Cable Management for Food and Pharmaceutical Industries
In the food processing and pharmaceutical sectors, exposed threads and textured surfaces can create accumulation points for contaminants. To mitigate these risks, LÜTZE offers hygienic cable glands made of corrosion-resistant stainless steel, featuring smooth surfaces and no exposed threads on the exterior. This design facilitates cleaning and minimizes potential accumulation areas.
The sealing material complies with FDA 21 CFR 177.2600 regulations and is resistant to standard industrial cleaning agents and high-pressure steam cleaning. For installations with additional EMC requirements, hygienic EMC cable glands that provide electromagnetic shielding for shielded cables are also available.
🌬️ Condensation Management with Pressure Equalization
Closed hygienic electrical enclosures are susceptible to internal condensation caused by temperature fluctuations during production and washdown cycles. To prevent this, LÜTZE has added hygienic ventilation plugs with pressure equalization to its portfolio.
Made from corrosion-resistant stainless steel, these plugs ensure effective ventilation and pressure equalization within closed systems while preventing the ingress of dust, moisture, and contaminants. Like the cable glands, the ventilation plugs feature smooth, easy-to-clean surfaces and use FDA 21 CFR 177.2600 compliant sealing materials.
🔍 Technical Details and Compliance with Standards
The elimination of exposed threads in external enclosure connections represents a significant evolution in hygienic design, in line with industrial guidelines aimed at reducing microbial colonization. Compliance with FDA 21 CFR 177.2600 is a fundamental requirement for elastomers used in these environments. Furthermore, compliance with EN 62444 for snap-in components ensures that mechanical strain relief and anchoring meet European industrial standards.
