✨ Next-Generation Li-Fi Solutions from Fraunhofer IPMS
Fraunhofer IPMS will showcase its optical wireless solutions for time-critical applications in industrial automation at SPS – Smart Production Solutions 2026. These innovative Li-Fi (Light Fidelity) technologies cover a wide range, from short-range sensor connections to galvanically isolated board-level couplers.
đź”— Bridging Cable Reliability and Radio Flexibility
As connectivity between robots, sensors, and machines increases, so do the demands for speed, availability, and response time. While cables offer high reliability, they limit the flexibility of moving systems. Radio communication, on the other hand, provides freedom of movement but can be affected by electromagnetic interference or crowded device environments. Dr. René Kirrbach from Fraunhofer IPMS emphasizes that in industrial applications, in addition to wireless data transmission, availability, speed, and predictability are also critical.
đź’ˇ Light-Based Data Transmission: Advantages of Li-Fi
Li-Fi uses light for data transmission and requires a defined line of sight between the transmitter and receiver. This ensures that the connection is unaffected by radio interference and electromagnetic effects. Integration is provided via Ethernet or UART/SPI interfaces, depending on the solutions.
🚀 Four Li-Fi Solutions for Industrial Communication
- Li-Fi Grathus: Provides Gbit/s optical data transmission over distances up to 10 meters and supports time-critical industrial protocols such as EtherCAT and PROFINET.
- Li-Fi TinySpot: A compact and energy-efficient solution offering short-range optical data transmission at data rates up to 20 Mbit/s for applications with limited space and power budgets.
- Li-Fi Power over Light (PoL): Transmits both data and power simultaneously to supply autonomous sensor nodes.
- Li-Fi GigaCoupler: A light-based optocoupler providing galvanically isolated Gbit/s data transmission for applications such as printed circuit boards.
These solutions address machine and plant engineering, robotics, and sensor applications with different transmission distances, form factors, and data rates.
🔍 Comparative Overview
Li-Fi Grathus provides Gbit/s transmission over distances up to 10 meters, supporting industrial real-time protocols like EtherCAT and PROFINET. A similar product, Signify's Trulifi 6016, uses 820 nm infrared LEDs to achieve data rates from 40 to 940 Mbit/s and typically offers latency lower than 1.5 ms.
