🚀 A New Step for Industrial AI from Phoenix Contact
Phoenix Contact has introduced MCP for PLCnext Control, an application that provides a standardized interface between industrial automation and artificial intelligence applications. This application enables AI agents to securely and controllably access automation data and functions via the Model Context Protocol (MCP).
💡 The Entire Automation Context with a Single Interface
Artificial intelligence can provide significant support, especially in commissioning, diagnostics, and maintenance processes. However, for this, it needs information from the actual automation system. MCP for PLCnext Control provides essential information from PLCnext Technology-based systems, such as device and firmware information, runtime and status information, diagnostic data, files, logs, OPC UA data, events, alarms, and notifications, through a single, standard interface.
⚙️ Fast Troubleshooting and Human Decision
This solution offers significant advantages in troubleshooting processes. In the event of a fault, AI applications can receive the automation context, such as process values, status, and diagnostic information, in a structured manner, thereby narrowing down possible causes of faults more quickly. Other information sources (documentation, service information) can also be integrated. Thus, AI performs faster and more accurate analyses by receiving context from the real automation system, not just isolated information. However, the ultimate evaluation and decision-making authority always remains with the user.
🔒 Industrial Security is Paramount
Designed for industrial use, this application also considers controlled access. Measures such as authentication, role-based access control, secure communication, logging, and request rate limiting are provided using existing PLCnext Technology security mechanisms. This limits the uncontrolled exposure of production data and supports industrial cybersecurity frameworks such as IEC 62443.
🌐 An Open Bridge: AI and Industrial Automation
The Model Context Protocol (MCP) is an evolving open standard that defines how AI models access contextual data and tools. The fact that this protocol runs directly on the controller enables the processing of diagnostic data at the machine level. With MCP for PLCnext Control, Phoenix Contact establishes an open connection between agency-based AI and industrial automation, making it possible to specifically use the automation context for AI-supported engineering, diagnostics, and service processes.
