🤔 Why Operators Should Be Empowered
Manufacturers should empower line operators to pause an AI-driven workflow when they spot an error. In these situations, a specific person should be assigned to resolve the issue, and operators should not be penalized for delays.
Otherwise, rewarding uninterrupted production while asking employees to use judgment creates a conflict where management leaves them on their own.
⚙️ The Operator's Role in AI-Driven Manufacturing
In industrial transformation, whether operators can intervene with software is a critical question. When evaluating AI-driven manufacturing software, the procedure for pausing a questionable recommendation should be addressed as part of the investment.
For example, an AI assistant in an assembly cell might generate setup instructions with an outdated process document. The operator notices that the specified revision differs from the controlled document at the station. The shift is behind schedule, and the supervisor wants everyone to make up for lost output. Following the recommendation is easy, but raising the inconsistency means explaining another delay.
The operator should not have to win an argument about the entire AI program to resolve this discrepancy. A specific, documented inconsistency should be sufficient to pause the affected instruction and make an accountable decision.
🛑 Assign a Clear Responsible Party for Pausing
A useful precedent already exists in manufacturing: Toyota's jidoka principle explains that equipment can stop when it detects an abnormality, and operators can stop the line themselves. The goal is to identify problems and prevent defects from progressing. Apply this principle to AI recommendations by defining which conflicts require intervention and who will resolve them.
A brief written rule is recommended: "When an AI instruction conflicts with a controlled procedure, a quality hold, or an observed operating condition, the operator may pause that instruction and notify their designated supervisor or quality lead."
The rule should define the approved return and the person authorized to release the job. Any physical stop should follow the facility's designated stop procedures.
The National Institute of Standards and Technology's (NIST) guidance on AI governance suggests defined pathways to raise risk concerns. Operators need clear authority over the affected step and the ability to escalate when the consequences extend beyond that.
They also need to know what to do if the designated decision-maker doesn't respond. Identify a backup person and an appropriate response time for the process before deployment.
📝 Rehearse the Disagreement
Behavioral evidence offers manufacturers a reason to take this issue seriously. In author Amy Edmondson's study of 51 teams in a manufacturing company, psychological safety was found to be associated with learning behavior.
Psychological safety relates to whether people believe they can take interpersonal risks within their teams. Challenging a recommendation supported by a supervisor is the kind of interaction leaders should rehearse.
Before introducing the AI workflow, conduct a brief exercise away from live production. Give an operator a realistic instruction with an inconsistency, such as the outdated revision in the hypothetical assembly example.
Ask the operator to use the actual reporting path. Have the supervisor respond, consult the approved source, and document a decision. Then, test the backup path in situations where the initial contact is unavailable.
NIST's guidance on testing human oversight suggests involving relevant participants and using scenarios similar to deployment conditions. For a facility, this means rehearsing more than just recognizing the wrong answer. Test what authority the person receiving the concern has and whether they can access the information needed to resolve it.
📊 Measure the Response to a Challenge
OSHA's program evaluation guidance lists response time and timely corrective action among useful safety measures. Adapt this approach to AI: Track the time from an operator's report to a verified correction or an explained decision to proceed. Separate waiting time from investigation time. Review unresolved cases at shift handover, with a responsible person for each.
Track preventable rework processes tied to the affected workflow, using the facility's designated quality definitions and a consistent measure like rework hours per batch. Compare similar products and operating conditions. Count any time saved, as well as time spent checking and correcting recommendations. Do not assign monetary value to a prevented defect unless evidence supports it.
Finally, ask operators anonymously if they know how to pause a questionable instruction, if they expect a timely response, and if a good-faith report would affect their position.
Compare these responses across shifts and track specific barriers. Treat a change in reporting volume as something to investigate. More reports could reflect better reporting or a less reliable system; numbers alone cannot distinguish these.
Before expanding an AI workflow, ensure an operator can demonstrate pausing and a supervisor can demonstrate resolution. Then, examine what happened to the last one.
