🏭 The New Frontier of Production: Implementation and Execution!
Elif Özaksu
  • Altanlar
    📈 Demand Is Rising, But What About Production?​
    The U.S. manufacturing sector is regaining strength: New orders are increasing, reshoring is gaining momentum, and capacity investments are back on the agenda. After years of uncertainty, this is a welcome change. However, it's important to be cautious about an assumption that emerges during growth cycles: the idea that stronger demand automatically leads to stronger production.
    ⚙️ The Bottleneck Has Moved Inside the Factory​
    Demand indicates what the market wants, but it doesn't mean your factory can deliver it consistently, profitably, and on time. The real bottleneck is now within the four walls of your factory. For much of the last decade, the focus has been on amplifying the demand signal, sharpening forecasts, and gaining faster insights into consumer behavior. These efforts are important, but many manufacturers have hit a new wall: they can accurately forecast demand, but still struggle to fulfill it on time and in full, leading to missed opportunities.
    📊 Data Discrepancy and Manual Processes Create Problems​
    We constantly encounter the same problems: Team plans in spreadsheets don't translate into actual production. Planning systems and the factory floor operate with different data sets and in isolation. Therefore, decisions made in one area do not reflect the reality in the other. Workforce alignment lags behind production needs. And when disruptions occur, decision-making slows down to the pace of the slowest manual transfer.
    For example, when a major retailer runs a promotion or changes a store layout, it often pulls forward catch-up orders for the manufacturer. When the promotion ends, the potential bullwhip effect continues, and the manufacturer is left with excess inventory because they don't fully understand the demand factors. The demand signal was clear; the challenge was to quickly and accurately translate it into the right production response. With data alignment and supply chain digitalization, limitless planning is what customers should aim for.
    💰 Investments Are Shifting to Execution Efficiency​
    The smartest manufacturers have already realized this. They are shifting their investments from chasing demand visibility to closing the gaps in planning and production. At the same time, they are working with their suppliers to ensure that raw materials do not disrupt production and order fulfillment.
    • They are implementing targeted automation where production is lagging.
    • By strengthening the link between planning and production, they better reflect what the factory can realistically produce.
    • They are replacing manual transfers and legacy systems with workflows that offer more proactive and systematic recommendations.
    • They are cross-training their workforce to ensure teams can adapt to changing priorities.
    This is where artificial intelligence (AI) and machine learning (ML) come in. The most frequent request I hear from customers is no longer another dashboard. They want systems that proactively tell them what to do and when to do it, rather than reactively investigating after the problem has already become costly. The days of relying on business intelligence (BI) tools to manually derive insights are over, as AI can now provide actionable insights. However, unactionable insights lead to the "so what?" question.
    🏆 Execution Becomes a Competitive Advantage​
    Now that demand is back and assets are generally comparable, the differentiating factor is how well you execute what you have. Two manufacturers can have almost identical assets, equipment, headcount, and order books, but achieve very different results. The difference is execution discipline. This involves producing the right product at the right time and continuously analyzing the cost-to-serve model, which should enable segmentation-driven order fulfillment.
    Seasonal pre-production reinforces this. Confectionery companies start making chocolates long before the holidays because they don't have the capacity to meet demand two weeks beforehand. This is not an execution decision: pre-produce what is guaranteed to sell, leave flexibility for slow-moving items, and avoid obsolescence from producing the wrong thing.
    Home improvement stores do something similar with hurricane preparedness: they pre-position generators, plywood, and cleaning supplies just outside the hurricane zone, then rapidly move materials into the most affected areas after the hurricane passes so recovery and repair can begin. In both cases, the advantage is not knowing what's coming. It's having the operational discipline to act precisely and anticipate the need.
    🎯 What Should Manufacturers Prioritize?​
    To translate this into action for operations leaders, three priorities should be focused on:
    1. Understand Where Production Loss Is Occurring: Before investing in new capacity or technology, diagnose the gaps in your existing operation. Production rarely leaks from one obvious place. It's lost through slow decisions, manual processes, and misaligned data.
    2. Close the Planning-Production Gap: Ensure your planning systems and factory floor operate with the same information. When the plan reflects what the factory can produce and the factory sees changes as they happen, you eliminate the lag that quietly erodes margin and service levels.
    3. Build Agility and Resilience: By cross-training your teams, you can shift resources as priorities change. Forecasts will never be perfectly accurate, lead times will never be perfectly reliable, and trucks will not always arrive when you expect them. Agility is how you absorb this variability without missing orders, and resilience is how you manage uncertainty, such as geopolitical events, regulatory uncertainty, or unplanned natural events.
    Stronger demand is a real opportunity, but it only rewards manufacturers who are prepared to translate it into consistent production. Capacity still matters. So does demand visibility. Available to Promise, Capable to Promise, and even more importantly, Profitable to Promise.
    Customer demand is what impacts both the top and bottom line. The manufacturers who will win this cycle are those who view execution as a strategic capability rather than an operational afterthought. The bottleneck has moved inside the factory, and the advantage awaits there.
