Innovation from FANUC Europe to Add Flexibility and Efficiency to the Production Line
FANUC Europe has launched its new P-55/15-21A paint robot to increase flexibility and reduce downtime in industrial paint lines. This six-axis robot is specifically designed to meet the evolving demands of automotive and general industrial coating applications.
Technical Specifications and Application Flexibility
- Wide Reach and Payload Capacity: With a reach of 2,050 millimeters and a payload capacity of 15 kilograms, it allows for the integration of various applicators, including rotary bell systems and conventional atomizers.
- Versatile Paint System Compatibility: Naturally compatible with 0K, 1K, and 2K paint systems, offering manufacturers the freedom to choose the most suitable application technology without hardware limitations.
Purge Management and Safety
To eliminate the risk of exposure to flammable liquids during paint changes, the P-55/15-21A is equipped with an external purge cabinet. This cabinet provides an ATEX Zone 1 certified controlled environment, preventing flammable paint vapors and volatile organic compounds from coming into contact with electrical systems.
Line Integration and the New R-50i Control Unit
- Flexible Installation Options: Easily adaptable to production lines with right or left mounting versions, floor, wall, inverted, or angled installation options.
- R-50i Industrial Control Unit: The P-55/15-21A is the first model to feature the new R-50i industrial control unit. Housed in a single cabinet, this unit reduces system complexity and improves installation times. It complies with IEC 62443 cybersecurity standards and offers superior processing performance.
- Ease of Maintenance: Servomotors use battery-less encoders, eliminating routine replacements. Trajectories are programmed with dedicated FANUC PaintTool software.
Industry Perspective
Jan Kamenicky, Director of Global and Strategic Accounts at FANUC Europe, states that today's operations require higher technical efficiency, and this equipment, thanks to its flexible installation options and new control unit architecture, provides operational freedom in paint technology while simplifying maintenance.
In the automotive industry, the transition to highly flexible paint lines is essential to make vehicle personalization seamless. Competitors like ABB or Yaskawa also prioritize modular designs and strict explosion protection certifications. The integration of battery-less absolute encoders has become a technical standard that reduces the total cost of ownership in coating robots by preventing the loss of robotic arm calibration data and eliminating the need to reset zero points after prolonged plant shutdowns. Furthermore, compliance with the IEC 62443 standard is a critical industrial requirement to protect operational technology networks against intrusions in connected manufacturing environments.
