🤖 The "AI Native" Deception: Why Pragmatic Solutions Are Better Than Marketing Gimmicks
🤔 The "AI Native" Label: Reality or Marketing Gimmick?​
In the world of industrial software, the term "AI Native," much like "Cloud Native," has become an overused and hollowed-out marketing label. In the last 18 months, established software providers in areas like supply chain planning, ERP, MES, and warehouse management systems have jumped on this bandwagon by adding generative AI assistants to their legacy systems and rebranding themselves as "AI Native" platforms.
However, being "AI Native" from scratch in critical physical operations is actually a disadvantage. So, what is the truth behind these claims?
🔍 Supplier M&A History: The Hidden Truths​
When you peel back the marketing layers of modern enterprise software, what do you really encounter? Over the past three decades, software giants have expanded their portfolios through aggressive mergers and acquisitions. They have absorbed Manugistics, i2 Technologies, RedPrairie, and dozens of local MES solutions.
So, did these companies really burn millions of lines of proven C++, PLC logic, and procedural execution code, and rewrite their entire portfolios from scratch as neural networks? Of course not! That would be commercial suicide and an operational catastrophe for their customers. Replacing a deterministic linear solver with a probabilistic neural network would lead to hallucinations in warehouse picking routes, the disappearance of supply chain constraints, and the failure of safety interlocks.
💡 The Pragmatic Alternative: Encapsulating IP as "Skills"​
What leading software vendors are actually doing is making a clever and pragmatic architectural trade-off. Instead of high-risk, multi-year "rip and replace" projects that would disrupt customer operations, software architects are encapsulating legacy intellectual property into reusable, deterministic "skills" for modern agentic AI.
In a production-grade industrial architecture, an "AI skill" is not an open-ended natural language prompt. It is a precisely defined, governed block of encapsulated domain logic:
  • Defined Interface: Standardized input/output schemas, clear parameter boundaries, and role-based permissions.
  • Deterministic Execution Path: The skill runs a proven linear programming solver, an optimized C++ routing algorithm, or a validated machine control script.
  • Safety and Governance Boundaries: Strict operational guardrails that prevent non-deterministic AI behavior from causing physical or financial chaos.
  • Domain Competency: A discrete, highly specialized capability such as "calculate dynamic safety stock under lead time variance" or "validate pump discharge pressure against operational envelopes."
By placing an agentic orchestration layer on top of the execution engine, the platform allows probabilistic AI to do what it does best: parse unstructured exceptions, reason over contextual anomalies, and communicate naturally.
🤔 The Buyer's Three-Domain Dilemma​
When evaluating enterprise platforms, operations managers realize that the story changes significantly depending on where you sit in the software stack. Industrial software spans three distinct operational domains:
  • Supply Chain Solutions: The core IP consists of decades of dynamic safety stock formulas, multi-echelon inventory constraint mathematics, and C++ linear programming engines.
  • Shop Floor Operations (OT/MES): The production floor cannot tolerate probabilistic decision latency or network outages in critical execution paths.
  • Enterprise Core (ERP/CRM/EAM): Here, an unfounded AI decision does not break a physical machine; it causes financial misstatements, regulatory non-compliance, or corrupted master data.
🚫 The Monolithic "Industrial Data Platform" Fallacy​
Before modernizing, enterprise architects must confront a terminological trap: the attempt to revive the old concept of an all-in-one "industrial data platform." Twenty years ago, calling an on-premise historian or MES database a "data platform" made operational sense. But in 2026, closed monolithic platforms are indefensible. No single software package can simultaneously serve as a sub-second edge connectivity agent, a hyper-scale analytical cloud store, an enterprise-wide knowledge graph, and a deterministic machine execution core.
Industry pioneers like Emerson/AspenTech, AVEVA, Schneider Electric, and Cognite are actively proving this shift. Instead of advocating for all-in-one platform silos, they are designing open, discrete industrial data fabrics:
  • Decoupling Data from Applications: Storing high-scale telemetry in cloud data lakes in open formats (like Apache Iceberg or Parquet).
  • Semantic Standardization:
