🚀 Beijer HMI/SCADA Platform
WebIQ, a fully web-based HMI/SCADA platform, offers cross-platform access, centralized project distribution, and real-time collaboration. Because it runs in the browser using open web technologies (HTML5, CSS, JavaScript), any device with a modern browser and network access can view and interact with the HMI. Your projects can be stored on a single central server or on an edge device. WebIQ allows multiple users to interact with the same project simultaneously. Whether monitoring values, acknowledging alarms, or adjusting process parameters, users can securely log in from different devices and work within the same live system.
🛡️ AutomationDirect Enclosure Series
AutomationDirect has added the Hammond ACE series of enclosures, which feature removable front panels for easy processing, quarter-turn latches for secure closure, and oil-resistant gaskets for superior protection. Constructed from durable Type 5052 H-32 aluminum with a smooth powder-coated finish, ACE enclosures meet NEMA 12 and 13, UL 508A Type 12, and IEC IP54 standards, ensuring reliability in demanding environments. They are compatible with both taraPlus and Hammond Heavy Duty suspension arm systems for ergonomic positioning. These enclosures feature cast aluminum and iron fittings and are rated up to IP65.
💡 Mitsubishi Electric HMI/SCADA Platform
Genesis version 11 is an HMI/SCADA platform designed for deployment flexibility. The software offers script-free application development and the ability to scale from single-node configurations to distributed, high-availability architectures. A secure-by-default application provides granular security controls and encrypted communications. The platform supports authentication standards like SAML 2.0 and integration with enterprise identity frameworks such as OIDC. This update includes a data-centric architecture with a built-in industrial-grade historian, universal connectivity with native integration across IT, OT, and IoT environments, asset modeling with a unified namespace, and adherence to industry standards. Key upgrades include enhanced visualization, comprehensive alarm management, and improved system control to boost operational awareness and responsiveness.
🌐 KEB Web HMI
KEB's C6 X1 Web HMI series is available in sizes from 7 to 21.5 inches, offering capacitive multi-touch screens as well as various mounting options. With IP67 protection and an extended temperature range, these HMIs are designed to operate in diverse environments. Simplified connectivity via Power-over-Ethernet enhances installation efficiency. Equipped with a Chromium-based HTML5 browser, they support IIoT edge applications. These HMIs also feature Helio, a code-free HMI development tool that streamlines the process of creating intuitive interfaces.
🏭 Pepperl+Fuchs Aluminum Enclosures
The marine-grade aluminum housing of the VisuNet FLX HMI series is designed for indoor and outdoor applications requiring extended temperature ranges from -20 to +50°C. The robust housing not only ensures optimal heat dissipation but also offers high resistance. If required, additional sunshades can be attached to the sides, top edge, and rear. These also serve as protection against rain and other environmental conditions.
🔒 nVent Stainless Steel Enclosure
The nVent Hoffman OICE-SS is designed for ease of use and meticulous protection. With an IP66 and NEMA 12 rating, as well as 4X protection, the enclosure can be used in a wide range of environments, including those requiring a corrosion-resistant design. The material used for this enclosure is 1.5 mm thick AISI 304L pre-grained stainless steel for the body and door. The mounting plate is 2 mm galvanized steel. The enclosure's body is folded and seam-welded, with a reinforcement plate mounted to the enclosure's roof. Its flexibility allows users to mount HMI displays in conjunction with a range of compatible accessories, such as nVent's new CS480 stainless steel swing arm system and stainless steel handles that can be mounted to the sides.
💻 Emerson HMI/SCADA Software
Movicon.NExT Version 4.4 features an updated industrial communication protocol driver for OPC UA, EtherNet/IP, and others to provide support for multi-station, advanced arrays. A new DNP3 driver enables Movicon.NExT HMI/SCADA to integrate with the energy industry and electrical grids. Optimized I/O operations more efficiently gather read/write tags for greater throughput, and open connectivity helps users easily connect with digital assets. Native support for Python runtime scripting within Movicon.NExT provides custom, cross-platform logic, while TimescaleDB support in the historian offers improved storage efficiency and higher performance.
📱 Weintek HMI
The cMT3218XP features a 1920×1080 HD display with 500 cd/m² brightness, a 1000:1 contrast ratio, and a wide 89-degree viewing angle. The touch panel supports multi-touch operation, including gloved use, while the IP66-rated front panel and NEMA 4 compliant aluminum enclosure provide structural strength. It is powered by a quad-core RISC processor, 2 GB RAM, and 4 GB Flash memory. Connectivity options include dual Ethernet ports, dual USB ports, RS-232 and RS-485 interfaces, plus MPI 187.5K and CANopen support. The cMT3218XP is programmed using EasyBuilder Pro, which provides built-in tools for alarm processing, historical data logging, and secure remote access for SCADA and IIoT deployments.
