✨ Ultra-Thin Fanless Industrial PC for Tight Spaces: SBOX-2625-SF Introduced! ✨
Elif Özaksu
  • Altanlar
    🚀 Next-Generation Solution in Industrial Environments​
    Modern factory automation and control cabinets in the retail sector frequently encounter overheating and complex thermal management issues due to dense component stacking. To address these challenges, SINTRONES Technology Corp. has launched the SBOX-2625-SF, an ultra-compact and fanless industrial computer that can operate seamlessly even in confined spaces. This innovative device aims to enhance edge computing capabilities while reducing energy consumption and hardware costs.
    🌡️ Innovative Thermal Design​
    Traditional fanless industrial computers typically use thick, finned aluminum casings to dissipate heat, which requires clearance around them. The SBOX-2625-SF, however, changes this approach. With its flat outer surface and high-performance thermal interface material (TIM), it transfers internal heat directly to the main machine cabinet or enclosure wall. This allows the metal mounting structure to act as an integrated secondary heatsink. As a result, the device's vertical height is reduced by 25%, and its mass by 30%.
    ⚡ High Performance with Low Power Consumption​
    The SBOX-2625-SF is built on an energy-efficient silicon platform. It features an Intel Twin Lake N150 quad-core processor with an ultra-low thermal design power (TDP) of just 6W. This low power consumption minimizes overall heat generation during continuous operations, reducing power distribution demands in enclosed electrical panels, remote terminal units, and retail self-service kiosks.
    🔌 Extensive Connectivity Options and Security​
    Despite its small size, the SBOX-2625-SF offers a wide range of communication and expansion interfaces necessary for edge telemetry, industrial machine vision, and programmable logic controller (PLC) interfaces:
    • Network Connectivity: Two 2.5 Gigabit Ethernet (2.5GbE) ports configured for segregated uplink and downlink industrial local area networks.
    • Serial Communication: Three legacy COM ports for RS-232/422/485 serial fieldbus interfaces.
    • Peripheral Bus: Up to six USB ports supporting external sensors, barcode readers, and human-machine interfaces.
    • Storage: Direct compatibility with industrial SATA solid-state drives.
    • Wireless Expansion: Dedicated M.2 expansion slots for WLAN modules (Wi-Fi/Bluetooth) and cellular connectivity (5G/LTE).
    • Hardware-Level Security: An integrated Trusted Platform Module (TPM) 2.0 crypto-processor verifies system boot integrity, secures cryptographic keys, and prevents unauthorized firmware tampering in surveillance and retail analytics systems.
    💡 Technical Details and Advantages​
    The Intel Processor N150 (Twin Lake microarchitecture) is built on the Intel 7 node with four energy-efficient Gracemont cores (without Hyper-Threading). It has a base clock speed of 0.8 GHz and boosted frequencies up to 3.6 GHz, also including 6MB of Level 3 cache. Compared to previous-generation 10W TDP embedded solutions, the Gracemont architecture provides higher instructions per cycle (IPC) throughput while reducing baseline electrical consumption by 40%.
    By transferring heat via conduction rather than natural convection, this system keeps junction temperatures within specified limits, even in fully enclosed and unventilated enclosures with an IP65 or NEMA 4 protection rating. The dual 2.5GbE interfaces reflect the transition of industrial networks from legacy 1GbE (IEEE 802.3ab) to multi-gigabit Ethernet (IEEE 802.3bz), supporting higher bandwidth IP surveillance video streams and industrial machine vision camera inputs without packet loss.
