💡 Revolutionary Solution from TDK SensEI: edgeRX VISION
Quality control in high-speed production lines has always been a balancing act. Traditional automated optical inspection (AOI) systems could lead to production stoppages by flagging even minor defects as "faulty." This is precisely where TDK SensEI steps in with edgeRX VISION!
🔍 High-Performance AI Compatible with Existing Cameras
edgeRX VISION offers AI-powered visual inspection capabilities without requiring you to change your existing production cameras. This system can detect issues such as surface defects, component deformations, and particle contaminations without stopping the production line.
⚙️ How It Works?
- Machine Learning Models: The system uses machine learning models trained with image data of both standard and defective parts.
- Semantic Feature Extraction: Instead of absolute pixel deviations, it extracts semantic visual features to distinguish true mechanical defects (scratches, cracks) from harmless conditions (dust particles, minor positional shifts).
- Edge Computing Architecture: All image processing occurs directly on edge computing hardware on the production line, without cloud dependency. This ensures low latency and high speed.
⚡ Speed and Efficiency
With the capacity to process up to 2,000 parts per minute, edgeRX VISION is ideal for ultra-high-speed production lines. This ensures that inspection processes do not affect the production cycle time.
📊 Integration and Analysis
The system operates as part of the broader edgeRX operational technology platform, collecting structured inspection telemetry for root cause quality analysis. This data allows engineers to correlate defect rates with operational timestamps, machine serial numbers, and raw material lot numbers. This enables a shift from passive defect filtering to proactive process stabilization.
🚀 Vision for the Future
Sandeep Pandya, CEO of TDK SensEI, states that they are focused on enhancing the platform's capabilities: "We plan to expand the platform's capabilities through advanced analytics, greater automation, and deeper integration with manufacturing environments."
🎯 Competitive Advantage
While traditional machine vision systems or some industrial AI vision platforms can process 500 to 1,200 parts per minute, edgeRX VISION's target throughput of 2,000 parts per minute makes it unique for ultra-high-speed electronic assembly and packaging automation lines.
